before work began
ready to start
painted
most of tile laid down
i have 2 florescent lamps i still need to install as long as several outlets that are going in. im also throwing in some old cabinets when i find them, im hoping to find someone remodeling there kitchen.
Are those individual squares on the floor? Are they the self-stick kind?
If so, did you use any glue? With the cold/hot temps, my tiles came up after a year or so.
After that, I sprayed 3M adhesive on the tiles first, and they stuck perfect for several years... till I sold it.
You just talking about that black can "Super 77" 3M stuff? (at least I think it's called that...or I'm thinking of tape).
I am doing a similar project that is protected from elements but will be at temp extremes and the tiles can be self stick or I can go the DIY adhesive route.
Trailer in the above pics has made quite a transformation, nice work![]()
Yeah, pretty sure it was a black can. But any of the spray adhesives should work.
The glue on the tiles is OK for a nice, warm house... but didn't do too well in my trailer.
heres a smalll update
tile finished, lights hung.
ac panel ( its not going to stay this way, its currently like this till i get the balls to cut a hole in my trailer )
and on the 6th day, he said let there be light
i still need to run some more outlets, and figure out what im doing with the cabinets. i also need to find some good cable runways. the ones i got are junk
Looks Awesome!
I would consider renting that out as a portable apartment!
The difference is night and day. Looks way better![]()
Hey David,
Where did you get the tiles that are 4x4? I'm thinking those might hold up better than the 1x1's
