Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
VP spec fuel at the track
    Re: VP spec fuel at the track
    Something prevents me from putting Something Called "Street Blaze" in my Bike.
    I spend far too much time with "Dollar Bill"
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    KB KB's Avatar
    Manchester NH
    Thanks folks. Sounds like I'll stick to the 93 pump gas and salads for lunch.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer Pittenger5's Avatar
    Austin
    Quote Originally Posted by Mongoose441 View Post
    Whats that supposed to mean whitey?
    Zip Tie Alley #505
    It's just really consistent pump gas, with ethanol. (Thats why they claim it's oxygenated.)
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    One thing you can do to make your $$$ C12 last longer is cut it 50/50 with 93 octane, which I've done. Makes that $$$ pail of gas go a bit longer and still keeps your motor from ping pinging.
    The fuels like MR9 add HP
    do that and you will make graham upset! or at least you will be upset when you get dq'ed
    -Benjamin Franklin
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Quote Originally Posted by daviid View Post
    I'll have to talk to Graham then since there is no reason to be DQ'ed for running spec C12 with spec-approved Pump Gas.
    spec + spec = spec
    Boston --> San Diego
    spec + spec = spec
    They can't reliably test for it, the test regimen depends on your fuel matching one of their three test samples, none of which are mixed. If he can't verify the contents, he can't say it's ok.
    Oct 2004
    Plantsville, CT
    spec + spec = spec
    LRRS FUEL RULE
    The LRRS rule book specifies that only “spec” fuels are permissible at LRRS events. Currently
    three brands of fuel are approved for use:
    ∗ VP C12,
    ∗ VP Blaze100,
    ∗ Shell 93 Octane pump gas from a pre-determined gas station
    Currently ONLY these fuels are permitted with NO mixing or blending allowed between these
    fuels and/or any other fuels or additives. (Two stroke machines are excluded from the fuel rule)
    http://lrrsracing.com/2008/LRRS_Fuel.pdf
    -Benjamin Franklin
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    LRRS FUEL RULE
    ∗ VP C12,
    ∗ VP Blaze100,
    Cool. Thanks for the clarification. I think Blaze100 will work for me..
    live to ride seth399's Avatar
    Feb 2007
    CA
    To original poster...from what you have explained you have no good reason to use the race fuel so ya, pump gas is your best bet. And to add what people have said it all depends on your tune/motor work to determine if race gas is needed/beneficial. In most cases with motor work, its better to spend a few bucks rather than grenade the thing. Even motocross bikes don't necessarily need it. My 250 2stroke runs on racegas and it runs awesome how it is set up currently, but I met a pro freestyle guy from england that runs 93 and just tuned his carb accordingly.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Good spots to get StreetBlaze of C12 outside of Loudon?
    Anyone?
    Oct 2004
    Plantsville, CT
    i went to new england cycle center, they wanted 68$ a pale, vs 45 @ the track
    -Benjamin Franklin
    Feb 2007
    CA
    is C12 $45 for 5gallon pale???
    Oct 2004
    Plantsville, CT
    i think its gone up 5$ it may have dropped. i havent boughten it in a while. i went back to 93
    -Benjamin Franklin
    Feb 2007
    CA
    Even if its 50-55 bucks I'd be very happy...sweet
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Quote Originally Posted by seth505 View Post
    At least. Think I paid 50 or 60 for 5 gallons of C12 in CA. Hence why I wanted to cut it 50/50... (or go to StreetBlaze..)
    You wouldn't need it Seth. 93 pump gas be just fine for your bike. Just HAVE to get it from the Shell right before the track, you know the one we didn't go to.
    Feb 2007
    CA
    o ya thats cool, I just want c12 for my mx bike. Last time I paid more like $70 for VP.
  1. Attention In The Haddock! - Spec Fuel
    By Johnny B in forum Pit Area
    Last Post: 05-17-16, 06:32 PM
  2. Fuel Spec at LRRS
    By Jim in forum Pit Area
    Last Post: 11-04-13, 12:36 AM
  3. Different VP Fuel at the track this weekend?
    By rolker in forum Pit Area
    Last Post: 04-16-11, 08:27 PM
  4. 450 Single Spec
    By wortown03 in forum General Bike Related
    Last Post: 01-26-08, 01:24 PM
  5. Wow! Spec fuel announcement
    By Paul_E_D in forum Pit Area
    Last Post: 03-23-07, 08:19 PM
