looked at it & said "gee, i've got alot to do before VIR in April."
Piston and rings going in soon. Valve adjustment also.
Shopped for pipes, will install this season
just looked at it![]()
checked the tire pressure, and didn't charge the battery
I kept looking at it and saying " I gotta take that tire off so Peter can put the new one on". As a matter of fact, I said that today. The new tire is right beside me.
it's a long and some what expensive list.
new rear sets... i left most of the last set in the turn 6 gravel.
new clip ons.... now both wrists are at the same angle, what a thought.
tore engine apart checked tolerances... no rebuild needed... yet.
replaced bent and broken clutch lever and front brake lever
new reeds
new tires
engineered new front brake resivior mount from old plumbers strap.
installed new front brake resivior
fixed HRC plastic hose rear brake resivior
ditched remains of air box and reconfigure crank breather vent catch can and hose (now with niffty one way valve)
rebuilt and adjust carbs.... still waiting on new jets.
adjusted chain
flipped gague cluster around so i can actually see the engine temp while on
the bike.
cleaned up wiring harness.
bled brakes with fancy racing fluid
fiberglassed front upper back together
repainted leftside of fairings to hide crash damage.
put on stickers
....i'm sure i'm forgeting something.... it was a busy winter.
So, when ya getting that tire on?
New Matris M4 steering Damper. new paint scheme on tank, and new Arai Profile British flag Helmet
I bought a bunch of stuff for the duc, but didn't do a damn thing with it.
2003 ZX7R
1995 916
I cleaned mine with a little pledge furniture polish a couple times, look at it a couple hundred times a day...sometimes I even touch it, and I charged the battery last month![]()
Mainly just fixed, some damage i had on a low sided on a on ramp on 295, damn OEM tires suck big time, now running PP's
New secret front master cylinder, new forks with emulators and springs. Hopefully a nice paint job and a rear shock rebuild before the 1st weekend.
I haven't tried it on the Moto plastics, I always use ArmorAll for the offroad stuff.
Pledge brings out the best looking finish on the matt black colors on the R7. All the plastic and painted parts I can get my hands on, get a coat of pledge on that bike. I still glaze and wax the painted areas once or twice a year, but pledge brings the best shine![]()
hawk:
remove all but the really necessary wires
remove rear brake reseviour (sp?)
remove stock gauges
remove various bits-n-pieces (stock rad shroud and side covers, etc, etc)
replace stock subframe w/ a shortened one - no more helmet lock!
remove flywheel & charging system
add digital temp gauge
new to me (used) rear shock being rebuild by pete
replaced the vfr rear w/ with a stock hawk rear
acquired a spare set of rims & mounted rains
replace stock airbox w/ uni's and rejet
replace stock shifter linkage w/ aluminum vfr direct-bolt-on setup
there's prob more, but i can't remember
rc51:
looked at it a lot. chained the oil/filter and raised the forks in the triples 10mm. oh yeh, and put air in the tires
Scott
Changed the oil and wiped the dust off![]()
M900ie
SS750
69 gas gusslin' Chevy
LRRS EX #418
Changed oil
Changed brake fluid
Installed Puig windscreen
Installed Pazzo race levers
Installed fender eliminator
Installed MTEC headlight
Installed xenon position lights
Mostly stupid little things.
I bought a new bike.
Boston --> San Diego
