Results 1 to 18 of 18
Real Fast Help
    Andover
    Real Fast Help
    Hi,
    I just took my track bike out of moth balls. 14 months and stablized gas. It turns over and catches and idles, it responds to idle adjust. But any kind of throttle or moving the choke kills it. I have a track day Monday and really don't want to burn the $250. It's a 2000 F4 any ideas?
    Thanks,
    Paul
    Waterbury, VT
    Real Fast Help
    Drain the gas out of the tank and replace it with fresh - you said it has stabil in it - but it might be shot anyway from condensation in the tank. Make sure the exhaust and air box are clear - no water build up, or critter nests. After that - let it warm up fully without touching the throttle. Good luck...
    SSearchVT
    Andover
    Real Fast Help
    Thanks, I was hoping I wouldn't have to drain it. I'll check and see if any body made a house in the air filter, it's happened before. Man I was really hoping this would just work. What would happen if I put in too much stablizer?
    Andover
    Real Fast Help
    Tank drained, all new gas, fully warmed up same thing. Airbox clear. WTF. How does the choke work on these things. Does it just add more gas? Looking down the throttle bodies there's this extra plate on top of the butterflies. Does that only open at high rpm on a servo?
    Andover
    Real Fast Help
    I got the thing to run in high rpm, once up there it's running fine. Those sliders do open and close based on rpm or air flow. Once the rpms are up I can move the choke without killing it. However, it will not run with out choke input at idle and the idle is bad. It's very hard to get it rev'd without killing it.
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    Real Fast Help
    Did you put new spark plugs in?
    Andover
    Real Fast Help
    No not yet. I called my mechanic friend and he says it sounds like the pilot jets are clogged. He said they had a lot of that this year because of the ethenol. He said they are the first thing to clog with varnish becasue they are so small and they operate at 1/8 or less throttle and "choke", which is where I'm having issues. Right now I'm trying to free them up with fuel injector cleaner, if not I'm going to have to rip the carbs out and try and clean them.
    At this point I do not have acces to new plugs anyway. I'll see how it goes.
    Thanks.
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Real Fast Help
    If you can't get it going, I may be up for buying the spot from you. It's a Seacoast day, correct? Good luck either way.
    Andover
    Real Fast Help
    Yes it's a Seacoast Day. If they are sold out you can have the spot because I doubt that the bike will be safe by tomorrow.
    Just Registered Doc's Avatar
    Jericho, VT
    Real Fast Help
    I second the pilot jets being clogged.
    Real Fast Help
    Have you tried draining the bowls to see what happens?
    Real Fast Help
    Just pull the carbs and clean the pilots. That's the only fix for this problem. Use small wire or dental floss to ream them out. Spray cleaner doesn't quite do it sometimes.
    Easy fix. Hardest part is getting access to the carbs.
    Apr 2006
    massachusetts
    Real Fast Help
    Tomorrow is not an option for me, work ruins everything.
    Jericho, VT
    Real Fast Help
    Why put off tomorrow what you can do TODAY!!?
    Northshore/Beverly, MA
    Real Fast Help
    yup pilots...pull the a/f mixture screws too when you clean.
    very small holes..check airjets while you are at it..they sometimes gunk up.
    Real Fast Help
    i like to drain the bowls and then will them with carb cleaner a few times (since carb cleaner evaps pretty quick.). i usually do this first to see if it can be fixed without dropping the carbs. half the the time it works all the time.
    Andover
    Real Fast Help
    Thanks, I just took the wife's bike. I'll get back on the carbs I hope this week. Running the cleaner through didn't work.
    Real Fast Help
    Wunna your spark plug wires is deteriorated or chewed through. Critters like using the insulation in their nests. You're dropping a cylinder...
  1. What makes the fast woods guys so fast?
    By gregp in forum Dirty Bastards
    Last Post: 10-18-11, 02:02 PM
  2. Replies: 12
    Last Post: 08-29-11, 10:28 AM
