Results 1 to 13 of 13
1 up 5 down switch?
    A.D.D or too much coffee?
    Oct 2002
    Johnstown, NY
    1 up 5 down switch?
    Is it possible for me to switch the shift pattern on a 2001 929RR to 1 up 5 down pattern without installing rearsets?
    Thanks ,
    Dan
    Ahhh, Dukey Wookey hurt his wittle hand, I'm the king of this gang now!
    2001CBR 929RR
    Lightly customized
    1 up 5 down switch?
    Should not be a problem.
    Let me research it and get back to you.
    degs
    1 up 5 down switch?
    Usually as long as the shift linkage doesn't pass through the frame (a la Yamaha 'R's') it's pretty simple. Usually nothing more than just flipping the linkage arm over on the shift shaft...
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    1 up 5 down switch?
    "Usually nothing more than just flipping the linkage arm over on the shift shaft..."
    Jay, he's talking about motorcycles......you perv.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    1 up 5 down switch?
    I was waiting for that....
    May 2003
    Lakes Region, NH
    1 up 5 down switch?
    just curious. Why would you want to do this?
    Bras cause cancer.
    1 up 5 down switch?
    In a word, easier. Yip, it's easier to shift that way. The best way I can explain is this: How many times have you hit a false neutral while UPshifting? Don't lie! Now how many times have you hit false neutral while DOWNshifting? That's right, NEVER! Switch your lever around, now you'll be every gear dead nuts when you UPshift...
    'Course, racers do this so they can UPshift in T-7 at Loudon...
    1 up 5 down switch?
    Coming out of a left hand turn with your knee on the deck it is risky to get your foot under the shift lever to upshift because you can easily catch your boot between the pavement and the lever. Also, when you are in a right hand turn way off the right side of the bike it is physically impossible for short guys (like me and most pro racers) to actually REACH the shift pedal, let alone get our foot under it.
    With reverse shifting you just have to tap down on the lever to upshift, much easier.
    Derek
    Diamond Geezer Kip's Avatar
    Nov 2002
    Cranston ,RI
    1 up 5 down switch?
    Just a little FYI not all racers use the GP style shifting. I for one don't like it. I would rather miss a up shift going down the front straight then missing a down shift going into turn one or turn 3 at 80-90 MPH.
    If you are asking what AMA racer uses the standard shift style, just ask the 2003 AMA superbike champ and he will tell you the standard is what works for him.
    May 2003
    Lakes Region, NH
    1 up 5 down switch?
    I will say that you both make good points. I didn't think of this in terms of racing because I never have raced before. Stoneman, you make a good point about the false neutral shift , done that before and I guess, just for regular riding (not racing) it would make more sense to false it into neutral while downshifting. I think that I would get awfully confused the first few times around though
    Bras cause cancer.
    1 up 5 down switch?
    Yep, absolutely standard for Mr. Mladin...
    ....with undercut gears and a shift kit. Makes a HUGE difference.
    Degs
    Northshore/Beverly, MA
    1 up 5 down switch?
    Good point about undercut gears, and shift kit....
    the gear box in one of those Zukis are tighter than a....well you know what I mean....
    Of course, maybe the brain is too narrow to become accustomed to a reverse shifting pattern?
    I'll ride em either way...
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    old suz came dat way
    my new 1 2
    dont make a diff 2 me i dont race
    www.bostonmoto.com
    Forum Rules
  1. Eliminate your Key Switch!
    By mzdagrl in forum Woodcraft
    Last Post: 01-09-15, 10:33 AM
  2. CRF key switch
    By CRF450F150 in forum Dirty Bastards
    Last Post: 08-01-07, 04:58 PM
  3. Clutch Switch??
    By tenkate76 in forum Bike Maintenance
    Last Post: 12-05-06, 10:36 AM
  4. oil switch
    Last Post: 08-12-03, 07:13 PM
  5. Kill Switch
    By nhroketboy in forum Pit Area
    Last Post: 04-10-02, 08:02 AM
