Results 1 to 25 of 26
1970 CB350 shifting question
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    So long story short, my girlfriend is getting a 1970 Honda CB350 from her brother as her first bike tomorrow. The bike is in really good shape except for the fact it won't shift out of first. I haven't tried to do anything to it yet so I'm just going by what her brother is telling me. He's saying that it won't shift unless you grab the shifter with your hand and give it a really good jerk. He seems to think that the linkage may have gotten bent when a friend of his was helping him take it out of the back of a truck or some pin may have fell out. I'm not sure if this is a common problem with these bikes or not, just looking for a "where to start" from people who may have had a similar problem with an older CB.
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Just Registered Doc's Avatar
    Jericho, VT
    Re: 1970 CB350 shifting question
    Shift shaft is bent.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Clutch gummy see if you can motorflush and new oil
    get her warm and adjust the clutch and make sure it move freely.
    yes shaft could be junk but my way is nearly free
    Glen Beck is John the Baptist
    Lube those linkages as well, if those gummed up they'll make it a PITA to shift as well.
    Lifer Danz19899's Avatar
    Grafton, Ma
    ya check the clutch before the shaft. if the clutch isnt disengaging when the levers pulled it can be a bitch to shift
    I had one that The shifter would move on the Spline and hit the frame. not letting the shifter engage in 2nd
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Aug 2004
    Baltic,CT
    Ancient history the splines on mine went...soft steel
    if linkage moves relative to shaft put in a dutchman
    If splines are completely shot test shifting with visegrip
    put it together in CORRRECT position for shifting
    drill and tap a hole in the gap between shaft and linkage so its 1/2 way in each
    depending on size either 10 or 1/4 inch screws
    put in a real screw like a socket head cap screw. <<< dutchman then be nice
    Senior Member nixoid's Avatar
    Sep 2005
    Watertown, CT
    The bike is toast - you should just give it to me. - But seriously... when she is done with it I may be interested. file that away for later.
    Apr 2008
    Salem NH
    I looked at it closer today and it seems that the shifter is either bent or wasn't put in correctly. I'm going to go through the manual to see the way it is supposed to be mounted and if it isn't wrong I'm going to order up a new one. Anyway this is the bike I'm dealing with
    Sep 2005
    Watertown, CT
    Sweet bike. Let me know if your sis doesn't take to it I may want to buy it from you/ sis/ bro[?] It looks to be in pretty decent shape.
    Kev
    Apr 2008
    Salem NH
    Quote Originally Posted by nixoid View Post
    Kev
    Girlfriend, she got it from her brother for free. He bought it 2 years ago and stripped it down to the frame, rebuilt the top end, sandblasted everything and powder coated it. There is no paint on the bike, he powder coated everything on the bike except the motor and trans. If she doesn't want to keep it I'll let you know but chances are it will be dropped a few times by then.
    Lifer stevecbr900rr's Avatar
    Sep 2006
    Malden, Mass
    Hey bitch i get 1st dibs!!!! Thats it i'm tellin Fran!
    1993 Honda CBR900RR
    1990 Suzuki GSXR1100
    1992 Kawasaki ZX750
    1996 Honda F3 Trackbike
    Apr 2008
    Salem NH
    Quote Originally Posted by stevecbr900rr View Post
    Steve, I already told you that you're only allowed on it if you sit bitch and wear your thong and wig so people think you're a chick
    Sep 2006
    Malden, Mass
    As long as i can wear the thongs with the elephant trunk we got a deal!...
    1993 Honda CBR900RR
    1992 Kawasaki ZX750
    Sep 2005
    Watertown, CT
    Quote Originally Posted by BCT748 View Post
    Yeah... first bikes are meant to be dropped. It's just part of the learning curve - at least it was for me.
    Lifer CMG241's Avatar
    Windham, NH
    Blake turn it into this and I'll buy it..
    Sep 2005
    Watertown, CT
    Blake - leave it just the way it is and I'll buy it.
    Just Registered Brian675's Avatar
    NH
    Question Re: 1970 CB350 shifting question
    Girlfriend.
    Why do you call your wife your gf?
    Apr 2008
    Salem NH
    So I figured out the shifting problem, he put part of the linkage in upside down
    I threw a new battery in it and found out it won't start. Pulled a wire and there is no spark. I pulled the cover off to check the points and when I hit the starter nothing moves. It spins with the kick start but still no spark. When I pulled the tank I found one green wire that isn't plugged in to anything and I can't find the other end of it. Time to start reading the wiring diagram
    Chris, I'd love to do a Cafe racer with it. I'm going to see how she takes to the bike and let her decide what she wants to do with it. I might just price out some parts to convert it just in case
    Sep 2005
    Watertown, CT
    I'm out of town for the weekend but when I get home I will look at my wiring diagrams and see what turns up. What is wrapped with it? Where under the tank if the wire? doubt I could be much help but I can give her hell for you.
    Kev
    Apr 2008
    Salem NH
    Kev
    I'm going out of town for a week on Monday so I'm not going to be able to look at it 'till I get back. 90% of the wiring connects under the tank. The wire might even go to the directionals because those aren't working right now either. I have the diagram so it's just a matter of reading it, I hate wiring. I also need to finish pulling off the side cover to check out why the starter isn't spinning the motor over, the starter does spin itself.
    Aug 2004
    Baltic,CT
    I think point gap is supposed to be about .016
    Clean point contacts with business card or any rough stiff paper
    Pinch points over card and stroke gently but firmly
    Sep 2005
    Watertown, CT
    Still gots? I'm still interested.
    NH
    Yeah he's still got it but not running.
    Sep 2005
    Watertown, CT
    Quote Originally Posted by Brian675 View Post
    Let him know I was asking about it if you could please.
  1. For Sale - Motorcycles | 1970 cl100
    By klp in forum For Sale
    Last Post: 06-16-18, 11:35 AM
  2. For Sale - Motorcycles | 72 Honda CB350 Cafe
    By timmyho414 in forum For Sale
    Last Post: 05-23-18, 11:23 AM
  3. For Sale - Motorcycles | 1970 Honda CT70
    By Dayon in forum For Sale
    Last Post: 07-21-17, 01:55 PM
  4. 1970 Honda CB-350 K2 Throttle Cable install
    By CharlieD in forum Bike Maintenance
    Last Post: 11-05-09, 05:03 PM
  5. CB350 track video
    Last Post: 12-26-06, 04:17 PM
