Results 1 to 4 of 4
1982 Honda CB 450 Nighthhawk carb problem
    I have a 1982 Honda CB 450 Nighthawk that has been in storage for the last four years. I removed the Carburetors and gave them a thorough cleaning. I also replaced the spark plugs, oil and fuel filter. The bike idles OK and at highway speeds seems to run good.
    The problem is that it runs rough at low speeds and hesitates between 3000-4000 RPM. Also if while stopped and you bring the rpm’s to 2000 the bike sounds like its missing. You can also hear a popping sound while decelerating.
    Does anyone have an ideal what the problem might be?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: 1982 Honda CB 450 Nighthhawk carb problem
    Quote Originally Posted by brindisi View Post
    Its a 82 cb 450
    www.bostonmoto.com
    Forum Rules
    Waterbury, VT
    How old is the gas in the tank, and what do the fuel lines look like? It might be worth it to pull the petcock off the tank, clean out the filter, replace all the fuel lines and vacuum lines, replace the gas, and add a second filter in line.
    SSearchVT
    Lifer Evil_Weasel's Avatar
    Over the Highside
    air leak on the carb boots. creating a lean condition. would be my guess
    get the bike running at idle and spray some carb cleaner/or ether directly at the little rubber carb boots. if the idle picks up your boots are leaking air. it's a common problem on older bikes pulled out of storage, the rubber gets dry rotted.
  1. For Sale - Motorcycles | 1982 Honda CM250c for sale
    By bbhzx10 in forum For Sale
    Last Post: 08-12-15, 04:09 AM
  2. 1982 Honda MB5
    By hondarider102 in forum For Sale
    Last Post: 09-10-10, 02:56 PM
  3. Anyone have old honda carb experience?
    By "Dangerous" Dan K in forum Bike Maintenance
    Last Post: 09-11-09, 09:47 AM
  4. Repair for 1982 Honda Hawk CB 450T
    By tatagatha in forum Bike Maintenance
    Last Post: 04-24-07, 02:51 PM
  5. Help!! I've inherited a bike!! 1982 Honda CB750F
    By PatSV650 in forum General Bike Related
    Last Post: 09-15-04, 10:03 PM
