Results 1 to 10 of 10
Brake light not working
    Hi, I'm new to the site and I'll be sure to make a formal intro soon. Anyway, I have an 01 R1 and I'm trying to get the bike inspected but my brake is not working. It lights up when turned on and the integrated blinkers work but the brake light does not light up regardless of which brake is engaged. Any ideas?
    Thanks in advance - chris
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Brake light not working
    Has it ever worked in the past or is this a fresh install that doesn't work properly?
    I just bought the bike a few weeks ago. I pulled the bulbs just now and they are LED bulbs. Other than that, I think everything else back there is stock.
    Candia, NH
    Is there any control circuitry included with the integrator that may be malfunctioning or not hooked up correctly?
    Your problem could be as simple as a loose wire somewhere in your harness or a partially fried logic board in your integrator. You need to provide a lot more detail in your problem description if you expect your problem to be troubleshot over the internet.
    Honestly, i have no idea if there is. I just replaced the LED lights with regular bulbs and the foot brake works but very, very faint. You cannot see the light work when the bulbs are put back in there casing. The hand brake does not work at all. I'm going to try and get it inspected and see if they fail to notice it. I'll take a picture of all the wiring when I come back and maybe you can tell me what wires I should check.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Quote Originally Posted by GreekR1 View Post
    I am thinking BRAKE LIGHTS might be important.. but hey that's just ME !!!
    Posted by Jane in BoxChat
    Lifer BostonSVkid's Avatar
    Dec 2005
    I bet you are having a grounding issue. Be sure the ground is connected fully and go from there.
    If its integrated as said above there shoulde be a modulator. Check out all the connections
    2006 Ducati Monster S2R800
    Welcome, you have some learning to do, grasshopper.
    I'm not going to waste any time on that comment other than WTF?
    Ok, I figured it out. The inspector said if my foot brake was any brighter he'd let me slide. But anyway the problem was that the piece that holds my brake lever in place was broken so when I'd press the the brake, it would not engage the switch. I ziptied it for now until I order the piece.
    I knew it would fail, but I was hoping they at least give me a rejection sticker to show I tried getting it inspected. I guess they do not give out R stickers for bikes.
    Now, my new battery just died. Kind of weird that it died so fast. I only had it on for about 5-10 minutes while I was checking the wiring and I even started it up for a few just to make sure the battery was dead. Now, nothing lights up other than my alarm.
    EDIT: still not quite sure why the foot brake is so dim.
    Likely broken wires.
    There might be some strands still intact in side the wire insulation that are able to transmit electriciy but I'll be willing to bet you get a high resistance reading if you put a meter on the wires.
  1. Replies: 0
    Last Post: 02-27-12, 10:34 AM
  2. Brake Light Help
    By Es_617 in forum Bike Maintenance
    Last Post: 06-17-10, 07:54 AM
  3. tail light out, but brake light works
    By Variablevalve in forum Bike Maintenance
    Last Post: 08-08-09, 09:28 AM
  4. Tail light not working, but I know why.
    By Ericthejet in forum General Bike Related
    Last Post: 06-03-08, 07:02 AM
  5. rear brake pedal/rear light not working
    By seth399 in forum Bike Maintenance
    Last Post: 04-10-08, 09:57 PM
