So I'm coming back from Bike night last night ( Good time by the way) and we take 110 into Lawrence no problem. We hop on 93s to come back into Boston as soon as we pass the 128 connector my friend speeds up to me and says that my brake light stopped working. WTF I press the brakes and ask is it just the brake light or the running light he said its completely off. I get home take the tail off check the fuses connectors and everything looks fine. Any one have this problem before? Any help would be great btw its a 04 zx6r
Dual Filament bulb is out change it....
LRRS EX 66
factoryeffex
AHH the 03-04 had LED's for tail lights
ogh u mess with the connector see if its loose or a bad ground and check the battery too make sure its all tight
LRRS EX 66
factoryeffex
or swap out another one see if its just the tail light...but as leds, they take a tone of abuse and use to kill..so they say
LRRS EX 66
factoryeffex
maybe a fuse?
Both of the brake light connecters on my '01 9R had wire break failures due to inadequate slack in the wiring harness. Maybe your 6R has the same issue. Pull out the bulbs and see if the connectors/wires are intact.
Sooo i took off the tail piece since i couldnt figure what was wrong since the connecters were in take and soon as i pull it off the one of the connectors and the wire come out with it guess it wasnt snaped in correctly but problem solved thanks guys
