Do yourself a favor and get the K&N oil filter. It had a nut already welded on so you can just use a regular socket to get it off, and is pre-drilled for safety wire for when you go to the track. As for oil, as said above, basically anything not energy conserving that is the weight you need.
Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
+1 on KN
