Results 1 to 25 of 38
2004 Kawasaki 636 ZX-6R - Unable to start_FI Light
    04 Ninja ZX-6R NinjaSwan's Avatar
    Southern NH
    Hey Gang, Been awhile since I've been on the site. Also been awhile since I have been on my bike, looking forward to getting back out. Poor thing has been cooped up in my garage too long.
    Went to pull the bike out today and ran into a problem will the FI (Fuel Injection) light coming on and the bike not able to start.
    Unfortunately I am not as technical and don't have the experience like you folks do with troubleshooting and fixing. Looking for any advise I can get or any known tricks to get the bike started so I can take it into a shop or fix myself
    2004 Kawasaki 636 ZX-6R - last ran end of last season (oct-nov).
    What should I be looking for and what information can I provide to help support my case?
    "Remember, some people are alive simply because it is illegal to shoot them"
    Banned G21forme's Avatar
    Lakes
    Re: 2004 Kawasaki 636 ZX-6R - Unable to start_FI Light
    Drain the tank and get some fresh gas
    p.s. I'm in hudson if you need a hand
    Southern NH
    Thanks for the quick response G21. I'll give that a shot. Will i need to flush the gas line as well? I'm in Merrimack if I end up needing help. Will probably have to do this on Saturday. Need to get a tube to cipher the tank.
    Because it's been sitting so long, I suggest charging the battery first.
    2 amps for 8 to 10 hrs
    who knows
    Also check and see if any rodentes have been chewing on any wires.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    You haven't mounted a fender eliminator recently have you?
    Member smkn-1's Avatar
    manchester
    in manchester if you need a hand
    battery probley problem
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    Check your interlocks, is it a F1 light or FI? Also does your bike have a service connector in the tail where you can get a code to read over the dash?
    Nov 2010
    Warwick, RI
    I had a similar problem with my TL, and it was the fuel pump relay. Is the fuel pump engaging or the relay clicking? You should be able to hear it.
    Lifer imkindafkedup's Avatar
    Jan 2006
    Saugus, MA
    when you turn the key to the on position, can you hear the fuel pump turn on?
    Jan 2006
    Saugus, MA
    woops, sorry i didn't read jb's post above me.
    Southern, NH
    This happened to my SV years ago.....chewed through my speedometer cables and everything else. Found 7 dead mice in my airbox......
    Southern NH
    I did when I got the bike several years ago. Is there a known issue? I did the majority of the install and KillBill helped me with the wiring.
    Everything seems fine with the battery but it could probably use a trickle.
    Southern NH
    yeah and we also stored the bikes in a frickin rat garage. Remember the chipmunk i cooked in my pipe? haha. damn rodents... Made a nice smell.
    I did however check and everything looks good. My garage is pretty closed off and don't have a rodent issue. Wires look okay.
    Southern NH
    Quote Originally Posted by jbmass View Post
    Checking this next.
    Southern, NH
    Quote Originally Posted by NinjaSwan View Post
    I sure do! Riding down 101a behind you and it smelled like a BBQ When you gunned it the thing flew out and almost hit me
    who knows
    hahahah, now that sounds like a funny day.
    On my Suzuki, there's a plug in the wiring harness that if I use a paper clip or something to jump the right wires, it puts the bike into service mode. I can then turn on the ignition and the FI light will then flash a certain number of times which corresponds to a particular fault code to tell you what's wrong.
    This may be the case with your Kawi as well and could be worth looking into.
    Lifer BSR6's Avatar
    The fact that it sat, and with the gas these days being the way it is, it's most likely a fuel issue. Either the bike just doesn't want to run on the old gas in the tank, or the injectors are gummed up. Even if you treated it before storage, I have seen instances where the treatment didnt' work.
    Whatever you do...Given the likelyhood of it being bad gas, make sure you have exhausted all options to address that scenario before you start to waste time or money on something else.
    Crappy gas won't cause it to throw a code. Crappy gas will make it run like crap.
    Not saying his gas isn't crappy, just saying I don't think that's the cause of the FI light.
    Silver Bullet Commuter fjrrider RI's Avatar
    Narragansett, RI
    Are u saying a gummed up FI system with laquer from evaporated fuel or moisture induced growth will not cause the code? Will FI continue to work on the bad gas without full fuel treatment and fresh gas? My carborated 500 vulcan was unuseable after 1 year needed a full cleaning.
    Yamaha lover
    Fuel injection is far less susceptible to gumming up. I don't bother using staybil in my FI bikes.
    Not saying it can't happen... just saying it's extremely unlikely.
    Southern NH
    I appreciate all the help on the thread here. I'll keep everyone updated.
    Last time the bike ran was Oct-Nov and it ran fine, right?
    Then it sat this entire time without any attention....battery tender and such?
    Charge the battery first.
    2amps for 8 - 10 hrs
  1. 2004 Kawasaki ZRX1200R
    By csmutty in forum For Sale
    Last Post: 08-29-10, 05:34 AM
  2. Looking for 2003-2004 Kawasaki ZX012r
    By iwannaride in forum For Sale
    Last Post: 09-15-09, 07:10 PM
  3. FS: 2004 Kawasaki 636 $4,750
    By Crash Dummy Denno in forum For Sale
    Last Post: 07-13-09, 10:30 PM
  4. 2004 Kawasaki ZX-6R $4000
    By Pittenger5 in forum For Sale
    Last Post: 05-27-09, 07:29 AM
  5. FS:2004 Kawasaki ZX6R 636 Race Bike
    Last Post: 06-10-08, 09:09 PM
