Results 1 to 8 of 8
Adding rear brake fluid to 99 Wide Glide
    Raymond NH
    Is it really supposed to be that difficult or am I missing something obvious?
    Member 7470racer's Avatar
    May 2010
    N. Attleboro, MA
    Re: Adding rear brake fluid to 99 Wide Glide
    If it is anything like my 02 Dyna - yes. Exhaust has to come off. Pain in the balls.
    Raymond NH
    At least I was changing the rear tire too, turns out the exhaust has to come off for that too...
    Old and Slow Sheppo's Avatar
    Westford, Ma
    That was one of my biggest complaints with my HD is the exhaust had to come off to due the rear tire. Turns out my BMW is sorta the same way. I have to loosen the clamp from the can to the mid pipe, then undo the bold that holds the can on and I can swivel it out of the way.
    Posted by Jane in BoxChat
    May 2010
    N. Attleboro, MA
    Yes, neither is a pleasure to do. But, once it's done - should be all set for a while. I did both at same time too. Turns out, my fluid level was fine. Just a maintenance check.
    Raymond NH
    The rear brake was quite soft, so I changed the fluid and bled the brake at the same time. Works perfectly now. I also replaced the battery, put a front tire on, and am in the process for replacing one fork seal and the fork oil on both sides.
    I was doing the work as a favor for friend but my kindness paid off handsomely, my friend gave me a 2006 Chevy Uplander that runs great and needs nothing in exchange for the work. I wasn't looking for a used minivan, but I will have two teen drivers home at the end of the week when my oldest comes home from college, and the extra car will probably prove quite handy.
    So what you're saying is this bike will not be winning Daytona anytime soon...
    Raymond NH
    Yup, but only because of my inept mechanical abilities. It has Screamin' Eagle pipes, a big bore kit, and lots of chrome, so it's clearly got the power to win.
  1. For Sale - Parts & Tools | Free Wide Glide tires
    By stoinkythepig in forum For Sale
    Last Post: 06-18-14, 05:00 PM
  2. Replies: 4
    Last Post: 01-26-13, 12:34 AM
  3. Brake Fluid
    By oVTo in forum Bike Maintenance
    Last Post: 05-26-09, 08:35 AM
  4. Replies: 5
    Last Post: 09-11-07, 09:15 PM
  5. brake fluid
    By double agent in forum Bike Maintenance
    Last Post: 04-23-05, 03:56 PM
