Results 1 to 15 of 15
bike hesitating around 60 mph
    Member dj 96yzf750's Avatar
    springfield mass
    when i got out of work today i was riding home and when i woul hit 4th gear around 60 mph my bike started really hesitating, kinda like bogging it kinda fels like rite when im in 4th and im going 60 or faster it fells like the bike barelty has any power, jus started happening out of nowhere
    Re: bike hesitating around 60 mph
    Check
    Battery terminals - make sure they are tight and clean
    Spark Plugs - inspect for signs of proper wear and check the gap
    Coils - Look for cracks or signs of electrical arcing
    Am I getting this right that this is ONLY happening in 4th gear? That's an odd symptom and I don't know what to make of it other than some type of timing retardation malfunction for that gear.
    springfield mass
    it happens in 4th 5th and 6th
    Also check
    Fuel for water
    Good flow to carbs.
    What do you have for fuel delivery system? Manual petcock or vac operated? Vacuum operated fuel pump or gravity?
    springfield mass
    and spark plugs are pritty fresh,where are the coils located?
    and the recent wrk ive done on my bike was a streetfighter headlight swap and ziptying some witres to the frame,could it be that i used regular gas instead of supreme for like the first time?
    Under full throttle or just cruising?
    Possibly, however I don't think that detonation would cause such a dramatic loss in apparent power. What grade of gas does the bike call for?
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    If you have a power commander on completely remove it and see of the symptoms go away. That is exactly what my rc51 did when the power commander failed.
    The coils are either located on the plug themselves (I doubt it for that year but I don't know). Follow the spark plug wire back to whatever it is connected to. You will probably have two coils, though there may be four.
    Yea in addition to what slammp said, can you give us a description of the bike with engine related mods, mileage, and the like. I am assuming it's a 1996 Yamaha YZF 750
    EDIT - If a mod wants to combine some of these posts feel free.
    springfield mass
    no theres no power commander on my bike and its under cruisin,i can haull ass until 60 mph im thinkin it has to be something electrical
    Lifer DuncanMoto's Avatar
    Before you get too into taking things out or disconnecting start with the easiest.
    The battery can cause this.
    You may have a damaged cell.
    Test the battery for it's voltage and health.
    Ask yourself.....
    How old is the battery?
    Did I let the battery discharge recently?
    Did I jump or charge the battery recently?
    springfield mass
    batery is kinda new but it drained out accident when i lleft in on last month ur right maybe i should take the bike for a nice long ride 2moro to se if it recharges
    springfield mass
    duncan moto your the man if this is the problem
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
    It may not charge enough.
    It's possible to damage a ceLl if you had to jump it.
    Idealy you could test the voltage. It should read around 13 volts.
    Most shops have a battery condition tester that can test the cells in about 1 minute.
  1. Replies: 68
    Last Post: 08-17-18, 12:53 PM
  2. For Sale - Motorcycles | 2005 Suzuki GSX-R 600 - Track Bike or Race Bike (missing title)
    By Mchristiansen in forum For Sale
    Last Post: 07-20-18, 05:23 PM
  3. For Sale - Motorcycles | 2013 Kawasaki ZX6R Class winning race bike/track bike
    Last Post: 03-02-18, 09:38 AM
  4. For Sale - Motorcycles | 2004 Ducati 999 track bike/race bike (1036cc motor) $7999
    Last Post: 09-07-16, 09:43 AM
  5. Replies: 10
    Last Post: 02-11-09, 10:30 AM
