Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Alternator? problems
    Member TimD's Avatar
    Woburn
    Re: Alternator? problems
    Its too damn rainy anyway... I was going to take a ride down today and try swapping regulators but I got tires of riding in monsoons
    Tim
    '05 GSXR1000
    Just Registered Origin's Avatar
    Lynn, Ma.
    haha yea..monsoons and tornado warnings are the not quite the ideal riding weather.
    Thanks again for everyones help..much appreciated.
    - TJ
    Northshore/Beverly, MA
    Quote Originally Posted by Origin View Post
    Update,
    His replacement R/R is bad...Dumping 17+ volts into the battery is not a good thing!
    Got another one coming...Hopefully TJ will be in the wind by this Friday.
    Woburn
    I just took another look at TJ's weird busted charging system
    It's still not charging, but I'm having a hard time finding out what the voltage is supposed to be at each point in the system.
    Voltage at the battery was 12.19 with the bike off, and about the same at idle. It would go up just slightly at high RPM peaking at about 12.4 but its not enough to keep the battery charged.
    There are 3 wires coming out of the stator all matching yellow. 2 of the 3 read about 3.3V at idle and climbed to just over 4v at high RPM. The third never read above .3v. All 3 are 0v with the bike turned off. Anyone know what the output of the 3 stator wires is supposed to be?
    Tim
    '05 GSXR1000
    you have to meter 2 wires at a time.
    Like checking a 3 phase voltage.
    Lynn, Ma.
    we did...we had ~.08 in every combonation but one.
    - TJ
    Did you guys check the voltage on the AC meter setting?
    It's AC at that point, not DC.
    It'll be DC once it gets thru the rectifier, regulator at the battery.
    If there is no voltage then, (it should be 50+ volts across 2 wires), then the stator is cooked.
    Lynn, Ma.
    im not sure he switched it over...I dont know.
    Im getting pretty burnt out on trying to figure this electrical crap out.
    - TJ
    I'm still up to my A$$ moving Bets out, all the little stuff is killing me!
    When I get freed up, I'll head on over, and we can see what's going on.
    Lets see what the middle of the week looks like Buddy...
    and again thanks for your help Saturday!
    Lynn, Ma.
    dont mention it, If you need anymore help with moving anything or setting anything up let me know.
    Tim and I found something to take care of the oil leak in the yamaha so I have that (HOPEFULLY) running safely again. So I have something to ride until i sell it mid Sept.
    - TJ
    I got probably one more run, and the place is empty, so we are good!
    Now we gotta sort thru it all and put it away!
    You can come over when I fire up the sound system!
    Then the neighbors are REALLY gonna love us!
    3000 watts of surround system on the 3rd floor, I don't think I'm ever gonna be able to really use it.
    Gonna have to wait till we buy a house I guess.
    Gimme a holler towards the end of the week....
    Woburn
    As I recall I left it in DC... oops, yea of course the power coming of the stator would be AC. (does that multimeter even have AC volts?) Measuring across 2 of the pins to the stator yielded 0v but the third acted the same as a ground. What I was wondering is if the stator is 3 coils, and all the wires should have the same voltage/resistance reading, or if 2 are coils and the third is a ground. 1 of the 3 wires from the stator acts like like a ground (no measurable resistance, and no voltage running or not) I'm not sure if thats a dead coil or if its supposed to be the ground.
    Tim
    '05 GSXR1000
    Quote Originally Posted by TimD View Post
    When I first measured the stator, all were giving me 50+ volts, so it pointed me towards a bad R/R.
    He's getting aftermarket ones, and I'm not sure if they are reliable. The last one he had in there punched out something like 17 volts, and was frying his battery.
  1. Alternator / AC belt question (car)
    By Ductard in forum Bike Maintenance
    Last Post: 07-28-15, 10:51 PM
  2. HELP. Ducati 1000ds SuperSport Alternator Cover
    By ThunderCycle in forum Pit Area
    Last Post: 08-10-12, 05:40 PM
  3. Alternator issue? (newbie question...)
    By Dragongirl in forum Bike Maintenance
    Last Post: 06-11-04, 12:05 PM
