Results 1 to 21 of 21
What am I missing?
    Lifer Pittenger5's Avatar
    Austin
    What am I missing?
    So the only thing I've done since the last time the bike ran was check valves, now when I turn on the petcock gas just drains from a hose on the bottom of the carb, as well as one of the clear ones that seems to come from the top of the carb. I know Im missing something basic ... so any suggestions?
    Zip Tie Alley #505
    KB KB's Avatar
    Manchester NH
    Re: What am I missing?
    You are missing the fact that you didn't put fuel stablizer in the gas before you put the bike away and now your float is tick.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Austin
    You are incorrect, I did put stabil in. And I ran the bike a couple weeks ago with no problems. Check the valves maybe 2 weeks ago, havent started it since, now this. Maybe the floats I dunno.
    Zip Tie Alley #505
    Meriden, Ct
    You are missing the fact that if you used the old-school "red" Stabil... then your gas still turned to shit.
    KB is right, float is stuck and not stopping the flow of fuel when the bowl is full.
    Pull and clean the carburetor.
    KB KB's Avatar
    Manchester NH
    If you didn't use the Marine "Ethanol" approved shit you might as well have jerked off in it.
    Or maybe you did and that's the problem.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Just Registered Omahastylin16's Avatar
    Apr 2008
    Scituate, MA
    Wirelessly posted (LG-LX260 POLARIS-LX260/2.0 MMP/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
    shit, good thing i didnt bother putting any stabil in this winter, my bikes running nice
    "Chatbox...It's like Vegas, for your fingers."
    Originally Posted by CBR_Knight
    in my own thread, let me post this:
    first of all, nothing about sex or play with a female seems interesting or arousing to me....
    "BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
    Lifer union's Avatar
    Blackstone, MA
    Quote Originally Posted by Omahastylin16 View Post
    +1 The R6 is running mint right now
    James
    Austin
    Mine ran fine 3 weeks ago, suddenly this ...
    Zip Tie Alley #505
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    Yeah, it sucks but, no biggie. You know the routine, drain, yank and clean. If you have to take off the tank, you might as well do the plugs ( if you didn't with the valve adj. ).
    Once the floats and their valves stick, it's a good excuse for some quality bench time. If you've thought of some jetting changes, now would be a good time.
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
    Austin
    I hate it when you people are right.
    Thats right, I said you people.
    Zip Tie Alley #505
    Austin
    Ok, Im gonna refrain from starting a new thread, but a new topic
    I need to grease the bearings on the trailer and the new wheels, is there any secret or tricks I need, or is it as easy as it seems? Attach the hose to the nipple squeeze a few times, and stop when stuff oozes out.
    Giggity.
    Zip Tie Alley #505
    "Attach the hose to the nipple squeeze a few times, and stop when stuff oozes out."
    are you greasing the wheels or hooking up with my ex-wife?
    later odieoh24
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Quote Originally Posted by odieoh24 View Post
    later odieoh24
    Obviously you don't know Richie.
    The only way he's gonna get an ex-wife is if someone cuts off his hand.
    Austin
    Quote Originally Posted by noxin View Post
    Low blow.
    Zip Tie Alley #505
    Raymond NH
    Giggity.
    You can blow the seals out the back with too much grease, too fast. You would think it would be impossible, because the pressure should force the grease through the outboard bearing, but I can assure you, it is indeed possible. If you know there's some grease in there already, inject new grease after a drive, while the hubs are nice and hot and the grease is thinned out.
    Gabba Gabba Hey Stiggy's Avatar
    Jan 2009
    I have always had good luck with a slight percussion adjustment utilizing the rubber handle of a screwdriver. A sharp rap directly to the float bowl should do the trick. Usually works well on lawn equipment and Harleys.
    06 RC46
    Lifer obsolete's Avatar
    Norf Sho
    So I guess red Stabil is bad... :-(
    -Alex
    Meriden, Ct
    It does not have any properties to prevent the ethanol from deteriorating.
    The new "marine" stuff specifically prevents the deterioration of the ethanol additives.
    P.S. Its blue/green in color vs. the old red stuff
    <== work safe... hehe CB750F's Avatar
    Newington CT
    lmfao hahaha
    1979 HONDA CB750F
    900+ miles and counting this season.
    I like my wifie how I like my bikes...... NAKED & READY TO RIDE.
    Newington CT
    i agree with stiggy quick tap with a rubber mallot or rubber handled screw driver if your carbs are clean normally un stick the stuck float. now if they are bad and have not been serviced in awhile. then fuck and give the bike to me and go buy a new lmao. ill will see to it the bike gets the beating it deserves
    1979 HONDA CB750F
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Ethanol Sucks
    Go on a marine website and see them rant
    I got a pint of water out of my mower last week and the hose looked like it was 100 years old
    Glen Beck is John the Baptist
  1. Something is missing
    By R7 in forum Dirty Bastards
    Last Post: 11-07-06, 09:27 PM
  2. Is it just me? or is something missing???
    By LM954RR in forum Pit Area
    Last Post: 03-02-04, 04:12 PM
  3. AM I MISSING SOMETHING???
    By SEVENSGT in forum Bike Maintenance
    Last Post: 08-02-02, 10:17 AM
