Results 1 to 20 of 20
WD-40 as chain cleaner?
    Apr 2008
    Boston, MA
    Question WD-40 as chain cleaner?
    I've been using WD-40 to clean my chains for a while now but I've been told that it isn't a good idea to use it because it makes the o-rings swell. Anyone ever have problems with this? I picked up some Motorex chain cleaner so I don't have to worry about it anymore but I was just curious if anyone has noticed any ill effects.
    May 2007
    Southern NH
    Re: WD-40 as chain cleaner?
    I once heard....second or third hand...of an aircraft maintenance manager who wouldnt allow WD40 in his hanger at all. Having heard that I limit the use of WD40 to careful cleaning of my wheels.
    I would pretty much disregard the above in favor of just about anyone elses more knowledgeable response...
    Muhammad Ali.
    Southern, NH
    I've been using WD40 for a while now too....
    I like WD40 for cleaning wheels, I use a paint tray and kerosene for cleaning chains.
    i hate these threads. use kerosene, or an actual chain cleaner (like motorex 611)
    Posting Freak boloson's Avatar
    Oct 2007
    u know what the best & cheapest stuff for chain cleaning & lube is??? dupont teflon spray. u can buy it at lowes for like $4. i heard wd40 dries out the o-rings
    Lifer Wishbone's Avatar
    Jul 2006
    I use maxima chain wax. Spray it on after a ride and rub the chain clean with a rag. It cleans AND lubes all in one shot.
    Winchester, MA
    For all intents and purposes, WD-40 can be thought of as kerosene with a little mineral oil mixed in. It will remove grease and replace it with a *light* lubricant. It will not hurt o-rings.
    Quote Originally Posted by boloson View Post
    Reading through my 848 manual and I remember reading that ducati recommends a teflon spray to lube the chain.
    i've been using this stuff for over a year now and love it. dries in less than 30 seconds, its clear, and its teflon.
    I would recommend hitting it in more frequent intervals than some of the thicker stuff (IE.. belray superclean, etc...).
    Posting Freak idratherberidin's Avatar
    Apr 2008
    Danvers, Ma
    Kerosene FTW. It also works awesome to get the release agent off of new tires.
    Oct 2007
    Quote Originally Posted by jcbell1007 View Post
    amazing stuff aint it? cheap, easy to use, no fling dries in seconds & can be bought at lowes. what more can u ask for?
    I haven't bought chain lube in 10 years, I clean and lube with WD-40. For what it's worth, it's also much cleaner/neater/less expensive to buy it by the gallon and use a hand pump spayer
    Just Registered Omahastylin16's Avatar
    Apr 2008
    Scituate, MA
    wd works fine by me
    "Chatbox...It's like Vegas, for your fingers."
    Originally Posted by CBR_Knight
    in my own thread, let me post this:
    first of all, nothing about sex or play with a female seems interesting or arousing to me....
    "BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
    duPont Teflon Wax for the win
    LRRS/CCS #627 JRide's Avatar
    Sep 2006
    Simsbury CT
    Been using WD-40 to clean my chains for a long time and never had a problem. I buy it buy the gallon and use a pump sprayer. After the chain is clean I use chain wax to lube up the chain.
    I also use WD-40 to clean my rims.
    John
    04 KTM 125SX
    05 CBR600RR
    07 KTM 250XC-W
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    What R7 said, I have not used "chain lube" in over 10 years. And to the people that put 2" of "chain lube" on
    FYYFF theothersean's Avatar
    middle of nowhere
    I dab a little wd40 behind ear before I go out for the night , it makes good whore bait .
    I too have been using wd40 to clean chains with out problems, I do use chain wax afterward though to lube the chain on the street bikes. the dirt bikes only get the wd treatment due to teh fact that all you lube is washed ritght off after the first mud hole you go through . so the dirt chains get cleaned after every ride with wd40.
    on the back cover of motorcycle consumer news was this little gadget that may be worth a try
    http://www.blackdogcw.com/ketten_max.html and can be used with wd40
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Infected Slyder's Avatar
    Concord, NH
    +1 on the Dupont multi-use stuff.
    Never gonna buy another can of chainwax again
    Also you can find it at Lowes and Ace / Foggs hardware. Probably cheaper at Lowes. It's around $8 a can up here at Ace.
    Lifer FirstDuc-1098's Avatar
    Central Mass
    Quote Originally Posted by theothersean View Post
    ... on the back cover of motorcycle consumer news was this little gadget that may be worth a try
    had something like that for my mountain bike, worked great!!!
    Southern, NH
    Just used the WD on my wheels yesterday.....phenomenal results.
    Thanks for the tip Kurlon
  1. Where do you buy your chain lube and cleaner?
    By BuXu in forum General Bike Related
    Last Post: 07-07-12, 06:54 AM
  2. carb cleaner???
    By burtonboarder23 in forum Bike Maintenance
    Last Post: 03-19-10, 04:21 PM
  3. Carb Cleaner
    By BMFR6 in forum Bike Maintenance
    Last Post: 06-01-09, 12:31 PM
  4. I'm out of carb cleaner this second
    Last Post: 05-15-09, 07:49 PM
  5. Bike Cleaner and Polish, What's everybody using??
    By 01 Taxidriver in forum Bike Maintenance
    Last Post: 06-11-08, 03:19 PM
