I've been using WD-40 to clean my chains for a while now but I've been told that it isn't a good idea to use it because it makes the o-rings swell. Anyone ever have problems with this? I picked up some Motorex chain cleaner so I don't have to worry about it anymore but I was just curious if anyone has noticed any ill effects.
I once heard....second or third hand...of an aircraft maintenance manager who wouldnt allow WD40 in his hanger at all. Having heard that I limit the use of WD40 to careful cleaning of my wheels.
I would pretty much disregard the above in favor of just about anyone elses more knowledgeable response...
Muhammad Ali.
I've been using WD40 for a while now too....
I like WD40 for cleaning wheels, I use a paint tray and kerosene for cleaning chains.
u know what the best & cheapest stuff for chain cleaning & lube is??? dupont teflon spray. u can buy it at lowes for like $4. i heard wd40 dries out the o-rings
I use maxima chain wax. Spray it on after a ride and rub the chain clean with a rag. It cleans AND lubes all in one shot.
For all intents and purposes, WD-40 can be thought of as kerosene with a little mineral oil mixed in. It will remove grease and replace it with a *light* lubricant. It will not hurt o-rings.
Reading through my 848 manual and I remember reading that ducati recommends a teflon spray to lube the chain.
i've been using this stuff for over a year now and love it. dries in less than 30 seconds, its clear, and its teflon.
I would recommend hitting it in more frequent intervals than some of the thicker stuff (IE.. belray superclean, etc...).
Kerosene FTW. It also works awesome to get the release agent off of new tires.
wd works fine by me
"Chatbox...It's like Vegas, for your fingers."
Originally Posted by CBR_Knight
in my own thread, let me post this:
first of all, nothing about sex or play with a female seems interesting or arousing to me....
"BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
duPont Teflon Wax for the win![]()
I dab a little wd40 behind ear before I go out for the night , it makes good whore bait .
I too have been using wd40 to clean chains with out problems, I do use chain wax afterward though to lube the chain on the street bikes. the dirt bikes only get the wd treatment due to teh fact that all you lube is washed ritght off after the first mud hole you go through . so the dirt chains get cleaned after every ride with wd40.
on the back cover of motorcycle consumer news was this little gadget that may be worth a try
http://www.blackdogcw.com/ketten_max.html and can be used with wd40
12 Vstrom 1000
09 KLR 650
(hers)
13 Vstrom 650ADV
09 KLR650
+1 on the Dupont multi-use stuff.
Never gonna buy another can of chainwax again
Also you can find it at Lowes and Ace / Foggs hardware. Probably cheaper at Lowes. It's around $8 a can up here at Ace.
