Results 1 to 14 of 14
brake bleed question
    This might bring up the same thoughts as dino oil vs syn, but here goes. ZX6R with ABS. Per SM no difference bleeding brakes vs non ABS model. Just ABS bike lines are longer. I used one a vacuum pump, starting with the right caliper due to routing, and then the left, then finally the MC bleeder.
    Pull the lever on the pump to build vacuum, loosen nipple, close nipple before fluid runs too low or pump runs out of vacuum, add fluid. Repeat until no bubbles.
    After that I repeated bleeding by pumping the brake lever a few times, hold lever, loosen nipple, close nipple before fluid runs too low or lever reaches bar, add fluid. No bubbles observed.
    Is it necessary to do the manual process after using the pump? I figured pump was most efficient way to remove most fluid and manual way was best to finish the job.
    Thanks,
    Greg
    2013 ZX6R-636
    Re: brake bleed question
    I'm not sure I understand what you're asking. Was there a mushy feel after the vacuum pump method? If not, then no need. But I usually have to do a few manual pumps to get a firm lever... hhaha.
    Oh hey, no there wasn't any mushy feel and no bubbles either. I just wasn't sure if it was necessary to do the old method when all done. Probably OCD, belt and suspenders thinking on my part.
    2013 ZX6R-636
    Lifer SwiftTone's Avatar
    Norwood, MA
    Not related but if you haven't already try speed bleeder valve installed on the caliper. Really love mine. I bled my whole system after rebuilding both front calipers in 10 min.
    I haven't, so thanks for the tip!
    2013 ZX6R-636
    TWINS! xrocket21's Avatar
    Central Maine
    To answer your question, I would do one traditional bleed after a vacuum bleed just to be sure.
    Lifer LuvDog's Avatar
    Ashland, MA
    I haven’t bothered with a manual bleed after the mityvac . So far I haven’t had any issues
    2003 ZX7R
    1995 916
    Central Maine
    I think it's definitely an extra step
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Speed bleeders are amazing.
    If I have to bleed the brakes on any vehicle, it gets these before I start the bleed process.
    I've always done a manual bleed after vacuum bleed mostly for peace of mind. The vac bleeders can and will pull air past the threads of the fitting and I make it a point to push even that smallest air bubble out.
    Lifer golden chicken's Avatar
    Attleboro, MA
    Took a test ride today and so far so good. My first brake bleed. Figure after doing various car, bike and boat tasks time to man up and do my own brake bleed.
    2013 ZX6R-636
    try speed bleeder
    No
    Did a test ride and all seems good. Thanks for the advice everyone.
    2013 ZX6R-636
  1. Rear brake question
    By Drewski in forum Bike Maintenance
    Last Post: 05-10-15, 10:27 PM
  2. Galfer brake pad question.
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-18-10, 09:43 AM
  3. Brake question
    Last Post: 07-24-09, 05:31 AM
  4. Brake line question.....
    By 13 in forum Pit Area
    Last Post: 04-12-07, 04:57 PM
  5. air in your brake lines? DON'T bleed them!
    By LiononaLeash in forum Bike Maintenance
    Last Post: 07-15-06, 08:39 PM
