Found my missing spark plug socket today.
Also found: the source of that strange ticking noise coming from my front sprocket cover whenever the chain was engaged.
you should be a dectective. or maybe a genius.
i really am starting to think it might be time for you to put the ratchets down!!!
Brent LRRS #772
2006 KTM 560 SMR
Fuck you clownOriginally posted by oreo_n2
lol...jesus dude...hahaha
that's ok..we all have our moments...right slutamis??![]()
I don't know about your garage, but in mine there are two rules that are never broken.
1. Put the safety glasses on before even plugging in the dremel tool or cut off wheel.
2. No beer until the job is done and the tools are cleaned and put away.
SSearchVT
I really want to laugh....but I am afraid if I do...I will do the same thing as you someday!!!Originally posted by slutamis
Oh fuck it......![]()
you garage sucks!!Originally posted by SSearchVT
2. No beer until the job is done and the tools are cleaned and put away.:
jobs in my garage are rated by the amount of beer that has to be on hand in order to complete the project.
for instance, an oil change is typically a 2 beer project.
now... what did slutamis do... you cant drop a cliffhanger like that and not elaborate!?!?!?!
Brent LRRS #772
2006 KTM 560 SMR
dude, putting your PANTS on is a 2 beer project.Originally posted by oreo_n2
This rule started because I dropped a circlip into the cases of a dirtbike. Simple top end rebuild turned into an 8 hour ordeal the next day with a hangover....Originally posted by bigred875
you garage sucks!!:
SSearchVT
you could be like legalspeed and try to remove a rear axle nut that is WELDED TO THE SWINGARM!!!!![]()
hehehe, that's great. Thanks dan, I feel a little better now.
www.bostonmoto.com
Forum Rules
and when he asked me to break it loose i didnt even look at it....the ratchet was already on it so i tried to use brute force (my foot) and SHATTERED the ratchet. after an attempt with the impact gun (obviously wouldnt work) i finally got down and looked at it to see it was welded![]()
shitty
