Results 1 to 23 of 23
carb cleaner???
    professional lurker burtonboarder23's Avatar
    Nashua, NH
    carb cleaner???
    I was looking at a couple different products that you put in your gas to keep the carb clean. Any thoughts on which products work and which products are just junk???
    Derry NH
    Re: carb cleaner???
    Anything reputable should be ok, but really only to keep them clean. You should break down the carbs and clean them thoroughly first, then you can use one of those additives once in a while if you feel so inclined.
    Nashua, NH
    Re: carb cleaner???
    how often should i have someone take the carb out and clean it?
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.06.3.1.20.0)
    Once.
    Then just keep it clean.
    Stabil or seafoam is what I use.
    SeaFoam definitly has a good cleaning effect, so if your bike runs well now don't take the carbs apart, just give a good SeaFoam treatment.
    Harlingen, Texas
    Re: carb cleaner???
    Just remember that all gasolines have detergents in them. You shouldn't be adding any extra cleaners except maybe once a year.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: carb cleaner???
    +1 seafoam
    High think today's gas is dirtier
    does not have many cleaners
    Glen Beck is John the Baptist
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Re: carb cleaner???
    seafoam
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    Re: carb cleaner???
    Startron fuel treatment is awesome.... like giving your carburated bike a shot of espresso....
    I dunno, you dress too fashionably to be a communist
    LRRS Novice #629
    I ride/drive:
    2000 Yamaha R6
    1996 F-350 4x4 diesel truck
    and anything else with serious hp
    Natick
    Re: carb cleaner???
    You know.. the autozone's near me stopped carrying it a while ago (seafoam) or else it's hidden somewhere ... I've been looking for it whenever I hit up auto sections (and walmart doesn't seem to have it either!) But.. I use stabil in the gas all the time and haven't noticed any good (or bad) effects.
    Aug 2004
    Baltic,CT
    Re: carb cleaner???
    Most walmarts have a can or two
    Dec 2005
    Near The Dragon
    Re: carb cleaner???
    Quote Originally Posted by DuncanMoto View Post
    Get out while you can
    Find your own path
    Senior Member nixoid's Avatar
    Sep 2005
    Watertown, CT
    Re: carb cleaner???
    If you do decide to break down the carbs and clean them the stuff I always use is Purple Power. Seems to work quite well. I have a lot of old Hondas and have pulled a ton ofthem apart. It isn't a bad idea to pull the brass parts and put them in a cleaner as well. I use Tarnx Stuff stinks to high heaven but does a great job. I don't know what bike this is for but the 10% ethanol gas seems to be destroying carbs. It hasn't happened to anything of mine but I hear it corrodes brass. Another thing you should consider is whenever you are storing the bike for any period of time is to drain the float bowls and empty the tank. I've never had any trouble starting a bike that was stored this way.
    Nashua, NH
    Re: carb cleaner???
    Its for a 2002 R6. The guy i bought it from went through and cleaned the carb before i bought it, just want to keep it clean rather then having to pay every year or so to have it taken out and cleaned again.
    Derry NH
    Re: carb cleaner???
    Then just regularly use Sta-Bil. Gas has detergents built in, so maybe use it like every couple tanks or so. Nice bike BTW, I have one in blue. Any pics?
    Nashua, NH
    Re: carb cleaner???
    once i recover from last nights festivities i planned on getting some photos up of the bike that were not taken with a blackberry. Should be up later today if i ever get my lazy ass out of bed
    Aug 2004
    Baltic,CT
    Re: carb cleaner???
    Come the winter sleep
    fill tank using blue/green stabil at least 10 miles so though entire fuel system
    Drain carbs or at least shut off gas and run the bike until the carbs are drained (bike stalls)
    Come spring run that tank out then fill up with 1 addition of cleaner and you will be fine
    Sep 2005
    Watertown, CT
    Re: carb cleaner???
    Quote Originally Posted by richw View Post
    What he said.
    Nashua, NH
    Re: carb cleaner???
    Yea i picked up a thing of seafoam that im going to run through the bike after this tank of gas is gone... hopefully going to get a couple tanks of gas through it this weekend
    Re: carb cleaner???
    Seafoam from autozone....
    Nashua, NH
    Re: carb cleaner???
    yea
    Senior Member cdseven95's Avatar
    Re: carb cleaner???
    On a car I pull a vacuum line (brake booster) and put some in there.. Where do you do that on a bike?
    Feb 2010
    Southwest CT
    Re: carb cleaner???
    Quote Originally Posted by rice_rocket View Post
    They changed the shape of the can . . . it's got a domed top now. If you're like me if it doesn't look like you remember it, it's not there.
  1. Replies: 28
    Last Post: 04-19-20, 06:29 AM
  2. WD-40 as chain cleaner?
    By GNTurbo6 in forum Bike Maintenance
    Last Post: 06-02-09, 06:39 AM
  3. Carb Cleaner
    By BMFR6 in forum Bike Maintenance
    Last Post: 06-01-09, 12:31 PM
  4. I'm out of carb cleaner this second
    Last Post: 05-15-09, 07:49 PM
  5. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
