Results 26 to 50 of 59
Brake issues
    Re: Brake issues
    and the rotor carrier?
    Lifer Pittenger5's Avatar
    Austin
    Re: Brake issues
    All brand new as of the first race weekend. Miss 1 full day both of the first 2 race weekends, and did this weekend, so say 2-2.5 race weekends on everything.
    Zip Tie Alley #505
    Re: Brake issues
    forks straight?
    (Shh, I'm fishin, here)
    Austin
    Re: Brake issues
    forks straight?
    Hope so.
    Zip Tie Alley #505
    Lifer obsolete's Avatar
    Norf Sho
    Re: Brake issues
    Could be f'd up out of the box man. I'd check how straight everything is. I know the rider isn't but that shouldn't effect the barkes.
    I'd go with Doug and check there's no shimmy. You could also use a roller depth gauge to check if the rotor is out of round. Kinda how you check forks. You just have to get the forks and gauge fixed on the same plane.
    -Alex
    Dec 2003
    Ma
    Re: Brake issues
    Did you compress the pistons all the way into the caliper when you re-bled the system?
    Winchester, MA
    Re: Brake issues
    Are your spacers correct? Wheel bearings ok?
    Given that you appear to have changed everything else, this seems to be the likely culprit.
    Austin
    Re: Brake issues
    Umm .. dunno. Josh and Chris bled them for me with the new master.
    Zip Tie Alley #505
    Austin
    Re: Brake issues
    How tough is it to change wheel bearings? I might just order new ones.
    Zip Tie Alley #505
    Re: Brake issues
    Chris and I did not, never heard of having to do that for bleeding?
    Dec 2003
    Ma
    Re: Brake issues
    And that's why I always work on my own bikes. So I know what I'm riding. Try compressing the pistons, air can get trapped in there and it won't be able to escape out of the bleeder valve.
    Re: Brake issues
    Good to know, I was waiting for an explanation on that suggestion.
    Austin
    Re: Brake issues
    Think I figured it out.
    So I throw the bike on the stand, have my dad hold the bars, grab the wheel top and bottom and rock it, and theres DEFINITE movement from left to right as youre looking at the bike. Fuck. Throw on the rain to double check (with good wheels) of course, no play whatsoever. Fuck. Go to put the new wheel back on and think of what Im gonna do. And theres no play whatsoever. None. Fine. So I dunno if something just didnt get seated properly or something or what, but it was more than enough movement to move the pads out. Especially over bumps.
    So hopefully its solved. Thanks to all the suggestions and such.
    Zip Tie Alley #505
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Brake issues
    Excellent !!! Glad you got is straightened out !
    Posted by Jane in BoxChat
    Austin
    Re: Brake issues
    Hopefully
    Zip Tie Alley #505
    Nov 2007
    Re: Brake issues
    That wouldn't cause an issue in only one specific area of the track, that would give you squish everywhere on the track.
    Josh and I rigged the new setup up properly.
    I wonder if the spacers or something were not lined up so when you tightened down the front axle nut and axle pinch bolts they were tight, but everything wasnt actually together properly.
    Makes sense that the area of the track where you get chatter and bumpity bumps on that thing would really exacerbate the play in the wheel and push the pads out.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Brake issues
    Who'd a thunk it. Sounds like a spacer wasn't seated right.
    I think YOU'RE not seated right. OSNAP! How's the wing feelin?
    Jericho, VT
    Re: Brake issues
    [SIZE=1] How's the wing feelin?
    Still hurts, but not as bad. Typing with 2 hands today. I Won't see the ortho until next week. Vicodin isn't all it was said to be. :offtopic:
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Re: Brake issues
    You are SO doing it wrong
    Norf Sho
    Re: Brake issues
    Vicoden works if you double or triple the dosage and wash it down with no less than 3 beers. At least that's what my doctor says.
    -Alex
  22. #47
    Austin
    Re: Brake issues
    Zip Tie Alley #505
  23. #48
    Norf Sho
    Re: Brake issues
    BOOYAKASHA!!
    -Alex
  24. #49
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Brake issues
    Axle tight then clamp in forks that's why an axel tool of some sort
    Glen Beck is John the Baptist
  25. #50
    Norf Sho
    Re: Brake issues
    Quote Originally Posted by richw View Post
    That's why an axel tool of some sort... WHAT!?!?! What does this axle tool of some sorts do? You always leave us hanging.
    -Alex
  1. Replies: 0
    Last Post: 02-27-12, 10:34 AM
  2. Front brake lever microswitch + brake bleeding
    Last Post: 05-05-11, 07:52 AM
  3. Duc Monster rear brake issues
    By Doc in forum Bike Maintenance
    Last Post: 06-28-08, 12:20 AM
  4. front brake issues??
    By FireFly in forum Bike Maintenance
    Last Post: 06-28-06, 06:01 PM
