Results 1 to 13 of 13
Brake Light Help
    R.U.N.V.S? Es_617's Avatar
    Brake Light Help
    So I'm coming back from Bike night last night ( Good time by the way) and we take 110 into Lawrence no problem. We hop on 93s to come back into Boston as soon as we pass the 128 connector my friend speeds up to me and says that my brake light stopped working. WTF I press the brakes and ask is it just the brake light or the running light he said its completely off. I get home take the tail off check the fuses connectors and everything looks fine. Any one have this problem before? Any help would be great btw its a 04 zx6r
    Re: Brake Light Help
    stock or aftermarket taillight assembly?
    Stock OEM
    Dual Filament bulb is out change it....
    AHH the 03-04 had LED's for tail lights
    ogh u mess with the connector see if its loose or a bad ground and check the battery too make sure its all tight
    ogh u mess with the connector see if its loose or a bad groaund and check the battery too make sure its all tight
    yeah checked the connector last night ima check the battery when i get home.
    or swap out another one see if its just the tail light...but as leds, they take a tone of abuse and use to kill..so they say
    who knows
    maybe a fuse?
    Yeah i know i had a Led Tail on my Gixxer and never had a problem until i got rid of it i saw the guy i sold it too not to long ago and he still had the same tail just one or two of the leds was out but other than that it was still working.
    Raymond NH
    Both of the brake light connecters on my '01 9R had wire break failures due to inadequate slack in the wiring harness. Maybe your 6R has the same issue. Pull out the bulbs and see if the connectors/wires are intact.
    will do thanks wil deff check on this in the next hour
    Sooo i took off the tail piece since i couldnt figure what was wrong since the connecters were in take and soon as i pull it off the one of the connectors and the wire come out with it guess it wasnt snaped in correctly but problem solved thanks guys
  1. Brake light always on - 06 R1
    By DaSarge in forum General Bike Related
    Last Post: 11-02-12, 01:40 AM
  2. Replies: 0
    Last Post: 02-27-12, 10:34 AM
  3. brake light gremlins
    By Paul_E_D in forum Bike Maintenance
    Last Post: 05-13-11, 03:11 PM
  4. tail light out, but brake light works
    By Variablevalve in forum Bike Maintenance
    Last Post: 08-08-09, 09:28 AM
  5. UFO Brake Light Kit
    By NinjaSwan in forum General Bike Related
    Last Post: 05-22-06, 03:05 PM
