Results 1 to 10 of 10
Broken battery terminal connector
    New Haven-ish, CT
    Broken battery terminal connector-7976e8ad-1b28-44d9-aa74-29de83d86c04
    Anyone know where I can get a replacement 90 degree battery connector like this?
    Re: Broken battery terminal connector
    Looks like Amazon might have something.
    If all else fails you can probably repair that one with some soldering and a couple copper strips
    eazy fix. this was my HOT MOD on the Race HawkGT
    Home Depot should have something. its just a ground connector
    https://www.grainger.com/product/22A...w63h3:20501231
    Arlington MA 02474
    As they said ^^
    Last night I did a little searching for 90 degree battery terminals, most were for heavier cable, like 1 ga.
    If it wuz me, I'd try the repair route, and look at the other end, too, and inspect the whole length for kinks etc.
    In the past I've bought 4 ga. and 6 ga. battery cables from ... somewhere, used them to run an extra ground from the battery neg. to the starter housing. (Yeah, I'm repeating myself, but it's worth repeating.)
    OK, brain started working -- I buy electrical supplies from Del City -- take a look at their battery cable assemblies, eg,
    https://www.delcity.net/store/Tinned...818636.h_89497
    -- up to 49" in 4 ga.
    and PS -- while I'm in electrical mode -- not that anyone asked -- this guy in NJ gives quick service, looks like similar stock to Eastern Beaver in JP.
    http://www.cycleterminal.com/index.html
    New Haven-ish, CT
    Poked around in Home Depot this evening. Found these https://www.homedepot.com/p/Southwi....0040/312648371
    Snipped off what was left of the old connector, stripped the wire back 1/4”, crimped this on, drop of blue loctite on the threads.
    Came in a 2-pack, so I’ll keep the other one around in case the same thing happens with the positive terminal.
    Broken battery terminal connector-9189bd8d-8d6f-4aa9-aaa4-c7ead0f9410c
    6 Not allowed! Not allowed!
    I've been looking less and less at HD, first I check online if I can pickup at my local NAPA (they give me a decent discount from the prices you see online), If I can't get it there in stock, or overnite, then my next search is McMaster-Carr, or Grainger's depending on the item, generally orders arrive overnight if ordered early enough
    Oct 2020
    Chelmsford, MA
    do what this guy does
    I'm seeing more and more of those vids pop up and... damn they get points for getting things done, but they're literally killing themselves and those around with their techniques in lots of cases. The crew making brake pads just hand shoveling asbestos fluff into pad molds...
    new Tesla Battery?
  1. Blue S#$% on + battery terminal
    By Paul_E_D in forum Bike Maintenance
    Last Post: 11-14-12, 05:47 PM
  2. Wanted: connector pin repair
    By sveesix in forum For Sale
    Last Post: 11-24-09, 11:26 PM
  3. Male/Female electrical connector
    By wookie in forum Bike Maintenance
    Last Post: 10-28-08, 11:25 AM
