"Harley Davidson: The most efficient way to turn fuel into noise without the risk of power and handling."
Selltekk.
-'04 Yami YZF600R (NOT R6)
- Uberfast Blue color
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
-Factory Pro Shift Kit
<a href="http://www.linkedin.com/in/davefortin" ><img src="http://www.linkedin.com/img/webpromo/btn_viewmy_160x25.gif" width="160" height="25" border="0" alt="View David Fortin's profile on LinkedIn"></a>
Its called a windscreen bearing.
sometimes its filled with blinker fluid.
Is it or is it not an aftermarket part?
Selltekk.
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
It's called "Why spend $30 on a camera mount when I can spend a bunch of hours fabricating a complicated mounting system that bolts across my bars and looks like crap?"
Just kidding. It looks like it would pass tech for a trackday as long as it is solidly mounted.
Thanks for the "fairing stay" info. I'm just wondering if one is made for my bike because I think I broke a mount for a screw that holds a small piece of plastic on the underside of the front cowl...right where it looks like the fairing stay on that bike is mounted.
I saw something online here:
58cycle Parts & Accessories Webstore
but it looks like OEM and goes inside the plastics...I was wondering if they made one for the )$ YZF600R like the did for the 97 model.
Selltekk.
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
Pretty sure the 97-07 YZF600 all have internal fairing braces which run up the inside of the cowl (as opposed to an external fairing stay which attaches from frame, arches up over triples and attaches to the top corners of the front cowl). Pre-97 YZF600 featured the external style.
I assume you're trying to figure out what mount you broke and what you need to replace/fix it? Here's the parts fiche...
Ron Ayers parts fiche
Zip-Tie Alley Racing
LRRS/CCS #103
