Results 1 to 11 of 11
sticky shifter won't pop out of gear
    Mar 2007
    Dudley, MA
    After I pull lever up (or down) it stayes in that position and I physically have to bump it up or down to get back to neutral - or to shift position. Otherwise it just stays up at the point which I shifted it to.
    Does not happen every time but enough to annoy and get dangerous, any ideas?
    Oh ya. 1 Gen SV
    Dec 2003
    Ma
    Re: sticky shifter won't pop out of gear
    think they're call 'shift dogs', simple little spring like deal, pretty cheap part, not familiar with the bike but not all that hard to change, on any bike I've done.
    First thing's first, how's the linkage look? Everything all greased & moving freely outside the cases?
    dirty linkage is cause of shift problems 90% of the time
    it could be just worn out as well and binding, shift linkage and brake caliper slide pins are the most important things to keep clean on your bike and most often ignored,
    fwiw, I completely replaced the shift linkage on my SV a couple times over the 135k I rode it
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    That happened to one of my bikes, thoroughly doused it WD40 and it's been fine since.
    Mar 2007
    Dudley, MA
    linkage looks good. not the cleanest but I will be sure and apply some love and lub.
    Member Ninjajim's Avatar
    Haverhill Ma
    If you go into lubing the linkage be sure to use something that will last. Wd-40 will clean it out, but it will not leave any real oil behind.
    Diablo Black 07 ZX-14
    Return spring popped off.
    Dec 2005
    Near The Dragon
    is the shifter on the input shaft or are there linkage/pivot points involved?
    reading comprehension issue.. my bad.
    consider marking the input shaft/linkage outer spline to same, and separating them to see if the linkage/pivot itself is the tight spot or if it is inside the case
    Get out while you can
    Find your own path
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Used to have problems with shaft bent check for damage too.
    Glen Beck is John the Baptist
    Oct 2004
    Southeastern Taxachusetts
    Or bent?
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
  1. new sticky tires
    By BluGixxer in forum General Bike Related
    Last Post: 05-19-11, 11:16 AM
  2. Replies: 0
    Last Post: 04-23-10, 10:22 PM
  3. sticky clutch plates
    By daviid in forum Bike Maintenance
    Last Post: 02-10-10, 01:50 AM
  4. Sticky rubber, 110/130
    By McBiggity in forum General Bike Related
    Last Post: 09-08-08, 04:10 PM
