Results 1 to 25 of 46
help gettin her started?
    Member cookie's Avatar
    Jun 2009
    jp
    hey guys. just tried firing up the bike. nothing. charged the battery up and it tried to crank up but didnt. i let it charge longer and then i kept getting a fast ticking sound which sounded like it came from a box behind the battery. my dash was lit up normal and i heard the fuel pump and everything turn on. any ideas what it could be?05 gsxr 1000.hope to get some advice.thanks
    06 Honda 1000rr MJD41985's Avatar
    Dec 2009
    Re: help gettin her started?
    That happen to mine... Believe it or not it was a bad ground on the bike. I was positive it was a good ground but not good enough. I also had that clicking nose coming from behind the battery. I'm sure you just need a better connection.
    PCIII, Ignition Moduel, Dynojet Quickshifter, -1/+2 Driven Sprockets, Flapper Mod, Extended Swingarm, HID, Nitrous, Custom Map, Corbin Seat, Lowering Link, Galfer Brake Lines, Greggs Flush Mounts, Comp Werkes Fender Eliminator, Speedo Healer, R6 Throttle Tube, Hyperflo Exhaust, Powder Coating.
    Sounds to me like a bad battery. Every time ive heard that fast ticking its been a bad battery, car or bike. Just not enough to spin the starter.
    battery or connection
    Wirelessly posted (BlackBerry8530/5.0.0.337 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Starter relay chattering. Your battery is jabunk
    Just Registered Doc's Avatar
    Jericho, VT
    Did you take the battery out over the winter?
    Jun 2009
    jp
    i hope thats the problem..i just bought the battery last march though? im gonna try to jump it tomorrow again.if i jump it and let it charge the battery should be all set right?
    Dec 2009
    Thats a no Doc.
    Jun 2009
    jp
    no doc. didnt take it out.just bought it so i figured it would be ok
    Jericho, VT
    If it freezes it dies.
    Quote Originally Posted by MysteriousR1 View Post
    Jericho, VT
    and he thought he wouldn't learn anything from the slow guys that go around in circles...
    Jun 2009
    jp
    hahaha.neva said that...i hope there is a damn warranty on the battery.im looking at the reciept and i bought it april 21 last year for 73 dollars..
    Jericho, VT
    But did it freeze?
    Quote Originally Posted by cookie View Post
    Before you throw money at a new battery, remove it from the bike and try a 2amp charge for 8-10 hrs first. The bike's charging system alone is not enough to bring the battery back up and it can be taxing to the entire system, battery included.
    If a battery freezes its no good?
    If it freezes uncharged it dies. With a charge it will be fine.
    Jericho, VT
    I thought it had something to do with spliting the cells... I have never had a battery come back from freezing... but I differ to Degs he is smarter than me.
    Jun 2009
    jp
    how do i tell if its frozen? do i hook up the battery into a battery charger which i plug into the wall?
    Did your car start every morning this winter? Mine did and it was freezing at least 60 nights.
    Listen for a rapid clicking sound in spring. Lol. You could try a charger for 8 hours at 2A like bergs says but that battery is always going to limp by at best probably.
    Jun 2009
    jp
    lol.now i know what a freezing battery sounds like. to bad it wont thaw out as fast as it froze
    Jericho, VT
    Yes but I thought the car battery was bigger and took longer to freeze than a small motorcycle battery.
    You car battery remains fully charged, thus is WON'T freeze...
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.0)
    Don't get me started here.
    Read the directions that came with your battery.
    Bring it to a shop and have them test the cells if it's an AGM.
  1. It's gettin' nice out......
    By JohnnyV in forum General Bike Related
    Last Post: 04-19-07, 04:49 PM
