Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Carb help please.
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Carb help please.
    Dll'ortos? What year 900SS do you have?
    Carb help please.
    Quote Originally Posted by rebelpacket View Post
    I thought it was in my Sig? (I have sigs turned off so I've forgotten). It's a 1995...
    Jul 2003
    Bozeman, MT
    Carb help please.
    If its a 1995 900SS, and its using the stock carbs, their Mikuni CV's.
    Carb help please.
    Okay, my bad
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    Carb help please.
    just put your whole carb assembly complete in a bucket of highly corrosive acid solvent for 3 days--no more--then immediately remove them, soak in a warm water soapy solution for 2 hrs, then rinse with cold water only + leave out in the sun to fully dry for 1-2 days. your problem will be solved!!!
    Doc, try the same thing!!
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Carb help please.
    Are you sure it's jetting? I *think* this motor still has a points ignition. If the points are worn or burnt, you can jet til the cows come home and it will never run right...
    There were motors using POINTS manufactured during this decade? That's incredible to me, I was under the impression that everything had converted by about 25-30 years ago -- I figured that mass produced CDI systems must have been cheaper (as well as better) by now.
    Amazing, you learn something new every day.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Carb help please.
    Apparently they switched in the early 90s. This motor is ancient tech. These are the bread and butter bikes for these companies. Development cost are close to zero, so profits can be high.
  1. Carb help
    By jaehok in forum Bike Maintenance
    Last Post: 05-22-12, 07:42 PM
  2. Carb syncing anyone?
    By Mr. Gixxer in forum Bike Maintenance
    Last Post: 11-03-11, 06:35 PM
  3. carb sync
    By johnnym in forum Bike Maintenance
    Last Post: 04-20-10, 05:33 PM
  4. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
  5. Carb Day
    By Stoneman in forum Bike Maintenance
    Last Post: 07-14-03, 08:51 PM
