Results 26 to 50 of 58
CBR 600 F4i - No Fuel Pump Prime
    Lifer Expat's Avatar
    Mar 2007
    Re: CBR 600 F4i - No Fuel Pump Prime
    Cabin Fever kb1's Avatar
    Dec 2008
    Down South
    Wirelessly posted
    Call me.
    FI-OH-ATE-TOO-SIX-nine-7-WUN-NYN-SEX.
    I was out tonight for the Bruins game and didn't get a chance to look at it. I plan to tinker with it again tomorrow, could I give you a buzz then?
    Wirelessly posted
    Is the nose of the bike on the bike? The tipover sensor is in the nose.
    the nose is not on the bike, but I have it on the ground in front of the bike facing in the right direction and upright.
    Quote Originally Posted by Expat View Post
    Glad you're enjoying yourself! But I do appreciate the advice on the phone tonight! Hopefully I can get it running without needing a visit from Paxton!
    who knows
    if you need some help I can come out and help you tinker... holla
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    Let me know if you want to borrow a good fluke meter, and I have a nice battery charger with jumping capability.
    Dec 2008
    Down South
    I will be tinkering tonight on it if you want to swing by, going to try and jump it, confirm that it has 12v across the pump, and then pull the pump and have a look at it if that doesn't work.
    Mar 2007
    Jun 2005
    Zener diode in the lock cylinder? Is the bike salvage or anything? Any lock damage?
    Why not just unplug the pump and put power directly to it? Ensure you isolate the correct leads and jump the battery to it.
    Dec 2008
    Down South
    Haven't had a chance to look at the bike again, been running around like crazy the past couple days. Will update next time I get back down there.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    my $ is on TOS not being oriented right... You can ohm it out if you have the right resistors handy.
    Dec 2008
    Down South
    Going to wrench on it tonight after my cycling ride for the night - will hopefully have a positive update!
    Dec 2008
    Down South
    Updates:
    OK after a busy few days I got back at it today. First thing I did was jump the bike using my car's battery; boy did that make a big difference! The bike definitely was down on power because a lot of crap lit up that didn't before, and the fuel pump relay did the double click as Degsy described, still no prime though .
    So now I turn the bike on, I hear click (the fuel injection light "lights up" on the speedo) and then another click 5 or 6 seconds later and the light goes out. No prime. I pull the tank out, drained it, and pulled the pump. I found that the wire that is getting power is the gas gauge wire . The wire that should power the pump is getting no power at all. Back traced that wire back and it comes from the same relay the fuel gauge wire comes from. I can get the fuel gauge wire to show power but not the power for the pump. That being said, I'm not an excellent electrical person so I may not just be touching the right connections with my gauge, I doubt it though because as I said I can show power on the fuel gauge wire pretty quickly.
    I tried to jump the pump directly, no dice. I connected positive and negative leads directly from the battery to the fuel pump connections and still no pumping. So I think my problem is two-fold, no power to the pump, and if power is there nothing happens. But again I could have been jumping it wrong, I'm very new to trouble shooting this.
    As I have the fuel pump out of the tank, does anyone have a spare fuel pump that I could plug in and see if it runs, if it does I know it's my pump at least? Anyone decent with electrics on the bike want to come and have a look? Bike is all torn apart so the wiring is easy to access. With my limited knowledge I'm pretty stumped right now. Bike does run though, I poured a little gas into each intake cycling and pressed the button, she fired right up and ran for 30 seconds before sputtering back to quiet.
    Please help!
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    My f4i did something similar and it was due to the wire contacts in the kill switch being corroded/ damaged
    Dec 2008
    Down South
    The kill switch works though, when I switch it off and on the fuel pump relay does the proper priming clicks...
    Middle of Nowhere
    I duno, its easy enough to check.
    Dec 2008
    Down South
    How do you check?
    Middle of Nowhere
    Take it apart, pretty easy to take it off
    Dec 2008
    Down South
    Just pulled it apart, cleaned the connections and put back together, switch works good but still no prime :-(
    Wirelessly posted
    Swap 2 relays over.
    Dec 2008
    Down South
    Just did it, nothing changed.
    Wirelessly posted
    Swap 2 relays over.
    Mar 2007
    Has anyone suggested replacing the fuel pump???
    Matt- just have Expat come by and pick it up and make him fix it for you.... sounds like the easiest solution to me.....
    Dec 2008
    Down South
    Quote Originally Posted by Lxpony View Post
    I have pretty much narrowed it down to the fuel pump itself at this point. I know the pump is getting power (I tested it), and it still isn't running. I applied power directly to the pump and it isn't running. So last night I ordered a new pump. Neil has been trouble-shooting it with me over the phone here and there, but I'm enjoying trying to figure this one out on my own.
    Wirelessly posted
    Take out the fuel pump and ohm out the wires. There could be a break in the wiring.
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    when my f4i felt starved at the end once, i thought it was the fuel pump too, but it was not, easiest things to check is the fuel line and breather hose from the tank, make sure its not kinked, and f4i's do not like running on empty, at least 1/4 tank , i'd splash some fuel into the carbs and try restarting it, it should start, thats if the engine is any good and if it dies then you know you aint getting fuel into the carbs, then i'd go with the fuel pump theory.
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
  1. 04 cbr 600 f4i fuel pump not priming
    By Bocephus5781 in forum General Bike Related
    Last Post: 04-07-16, 07:35 PM
  2. i need a fuel pump!!!
    Last Post: 06-05-11, 08:27 PM
  3. Not the fuel pump
    By Nate Dawg in forum General Bike Related
    Last Post: 08-10-08, 08:05 PM
  4. fuel pump???
    Last Post: 08-10-08, 12:54 AM
  5. Fuel pump goes *wwweeeeeeee*
    By darkchylde51 in forum Bike Maintenance
    Last Post: 05-07-05, 09:31 AM
