Results 1 to 12 of 12
CBR929, bike shuts off when taken out of neutral
    Bike was a racebike. Wiring all hacked up. But, it worked. Aftermarket tach/gauge, no original cluster. Rocker switch for on/off. Killswitch works. No wiring going to clutch lever switch. Wiring hasn't changed that I know of since I got it.
    So I had to swap the motor due to it slipping out of gear. Put the new motor in, runs great.
    Only issue, whenever I put it in gear, it kills the bike. Like, killswitch kill. Then, no start until you put it back in neutral.
    Checked/swapped/bypassed the kickstand sensor, no dice.
    Any ideas on what else it could be?
    I wish there was a logic tree for the ignition kill system on this bike like there is for the fuel pump.
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    Re: CBR929, bike shuts off when taken out of neutral
    Clutch or side stand switch or wiring. Don’t know if the switches are no or NC, but you probably have a cut wire, if the switches test ok. My guess.
    diagram has the clutch switch and the side stand switch linked!
    CBR929, bike shuts off when taken out of neutral-929wiringdiagramuscanada-jpg
    Lifer Falko's Avatar
    MoonTown
    Sounds like a clutch switch.
    Yup, gotta be it. I’ll trace it out and jump it tomorrow, see what happens.
    What???? No.... you're supposed to tell us that we're wrong without trying any of our suggestions.
    That's how it works on the internet ya fukkin noob.
    Knob. Not n00b. Duh.
    I already checked the noob knob, didn’t fix.
    Somehow, previously to this motor swap, the clutch switch was jumpered somehow. Of course, I can't find any evidence of this.
    Jumpered the two pins going to the left side switchgear (clutch switch), and boom, she'll crank over in gear. Also found an intermittent kickstand switch connector (switch itself tested fine previously, but the connector was junk), so I'll swap to a known good one.
    Still a mystery how this thing ran before.
    Going to wire in the clutch switch using the connectors for the front brake light switch.
    I mean... That bike did catch on fire lol.
    We have a winner!
    We have a winner!
    Funny story... We were working on a Volvo 242 for lemons and the same guy who caught that bike on fire also caught the Volvo on fire while soldering wires... Coincidence lol?
  1. No Neutral
    By slammp in forum Bike Maintenance
    Last Post: 03-12-12, 08:57 AM
  2. I need brake rotors for cbr929 or 954
    By dave6688 in forum General Bike Related
    Last Post: 08-24-09, 10:32 AM
  3. Bike shuts off after messing with the clutch lever
    By BrandonRoy in forum General Bike Related
    Last Post: 08-05-08, 02:03 PM
  4. FS: In NH; 2001 CBR929
    Last Post: 05-01-08, 04:49 PM
