Bike was a racebike. Wiring all hacked up. But, it worked. Aftermarket tach/gauge, no original cluster. Rocker switch for on/off. Killswitch works. No wiring going to clutch lever switch. Wiring hasn't changed that I know of since I got it.
So I had to swap the motor due to it slipping out of gear. Put the new motor in, runs great.
Only issue, whenever I put it in gear, it kills the bike. Like, killswitch kill. Then, no start until you put it back in neutral.
Checked/swapped/bypassed the kickstand sensor, no dice.
Any ideas on what else it could be?
I wish there was a logic tree for the ignition kill system on this bike like there is for the fuel pump.
