Results 1 to 10 of 10
problem with the duc, shop recommendations? (boston area)
    .... duey's Avatar
    Wilmington MA
    Ok well myself and a bunch of buddies are completely baffled on why the 916 isn't running right. So i've decided on bringing it to someone to look at as i don't have the time/resources to troubleshoot this issue anymore.
    I'm not trying to bring it to the dealer since most of them will either : a) rape me on pricing or b) tell me they can't work on it for weeks. I have exhausted my skill level with diagnosing this problem.
    So if anyone of you guys know anyone local or if you yourself can help me out i'm willing to pay/provide beer(s)/food what ever it takes to resolve this issue.
    thanks,
    duey
    this is the thread regarding the issue(s) i'm having ; http://www.ducati.ms/forums/showthread.php?t=4462
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Theres a guy in Rockland, MA who specializes in Ducati and BMW bikes (but also works on everything else except harleys).
    All Performance Cycles
    Motorcycle Repair & Service
    290 Weymouth Street
    Rockland, MA, 2370
    781-878-8719
    The guys name is Tim.
    He ended up repairing an issue with my CBR. Does really good work, very competent, competitive labor charge, and very friendly.
    Sounds like a blocked fuel filter or a blocked gas cap vent. The fuel pump can only supply as much fuel as can be replaced by air in the tank. Try running it with the gas cap open and see if the problem goes away.
    derek
    Senior Member double agent's Avatar
    Sep 2002
    acushnet - yates replica
    try dunbar cycles in (I think brockton).
    If money is the root of all evil,
    why do churches beg for it?
    Not taking any bikes for service until end of May or June.
    Personally speaking, their customer service skills suck. Very high prices too.
    derek
    .... duey's Avatar
    Wilmington MA
    thanks for the help guys. much appreciated
    Degsy,
    I've already gone and changed plugs, fuel filter, and new eprom chip (ferracci). And just last night we determined that i'm getting a definate ignition cut. Ground to the coils remain fine, power to the coils however are getting cut, i have not had a chance to really sit down and trace the wire to see how/why the coils are getting cut like that, another thing that has been killing me is that this ONLY happens when the engine hits 180degree's on the dot, before that she runs like a champ. Anymore idea's? If i had more time on my hands i'd like to figure out this problem by myself, but i work 2 jobs and the duc is my main mode of transportation.
    thanks,
    duey
    Does the fan come on at 180 degrees? I'll have to check what temp the fan kicks in on those bikes, but something that happens at 180 is causing a short probably.
    1. Fan (if it comes on at 180 then it might be shorted or jammed up, causing an overcurrent condition). Check that it turns freely. Try disconnecting it and see if the problem goes away.
    2. Something in the fi mapping at 180 degrees is screwing things up
    3. A component is getting too hot. (a coil maybe, or a spark plug?
    derek)
    If your friends have a similar ducati, then try swapping out the coils and testing. Rectifier too. One at a time obviously, to find the faulty component.
    Atlanta, GA
    Does the engine have an O2 sensor? I.e. does motor run open loop until it hits operating temps then go into closed mode and change map for fuel/spark?
    I don't know if bikes or ducks have O2 sensors on them but maybe they do?
    Andrew
    03 Suzuki SV650
    Member Dave B's Avatar
    Apr 2006
    possibly sliding towards the wall in (insert turn # here)
    Did you try www.easterncycleducati.com in Beverly? Paul and Steve are certified techs, great guys, and they work on several racers' bikes. Highyl recommended.
    LRRS #699
    (Insert witty comment here)
  1. Exhaust pipes ceramic coating shop in the Boston area?
    By xxaarraa in forum Bike Maintenance
    Last Post: 08-04-15, 09:44 AM
  2. Reviews on a Boston area auto paint shop?
    By xxaarraa in forum General Bike Related
    Last Post: 05-10-15, 10:41 AM
  3. Recommendations for radiator shop in Boston area?
    By NlC0 in forum Bike Maintenance
    Last Post: 08-04-13, 10:51 AM
  4. Boston Area Recommendations
    By Legion1440 in forum Rides & Events
    Last Post: 05-05-09, 08:38 PM
