I was curious what you guys are using. I usually clean it with wd-40 then use chain wax but i want to try something different..
Maybe i'll try the motul lube. I use their Motul E-Tech oil in my bike and like the way it shifted after i started using it..
I run E-Tech in my Strom. Nice stuff and priced right.
Try Motorex 622 Strong. Best chain lube I ever used.
Check out my eBay store!
Dave - Motorace - Michelin
Anybody ever try that dupont teflon lube? I haven't used it myself but I have heard it works wonders.
I may be wrong but I thought wd-40 was bad for the o-rings and not recommened.
I use Kerosene to clean my chain then I just lube it with Suzuki chain lube.
This seems to do the trick for me, however I did hear good stuff about the Dupont teflon spray and I will try it next time because it's clear so your chain looks clean.
That is just an urban ledgend. Any chain worth its salt will not be damaged by WD-40.
I use straight up WD-40 as my only chain lube. It's inexpensive and reduces the parasitic losses in the final drive of the motorcycle.
Watch all the naysayers come out of the woodwork saying WD-40 doesn't lubricate chains.![]()
coincidentally, my buddy with a zx12 uses wd-40 too. It is o-ring safe, but it breaks down quickly... you have to apply every 200 to 250 miles. He kept a small can with him on the bike.
Exactly why I had to get some from you... great stuff.
WD40 to clean, and Chain Wax to lube.
I'm going to have to try the kerosene thing for cleaning.
"Harley Davidson: The most efficient way to turn fuel into noise without the risk of power and handling."
Selltekk.
-'04 Yami YZF600R (NOT R6)
- Uberfast Blue color
-Two Bros. Exhaust
-OES Sliders
-Helibars
-Mototeck Flushies
-Factory Pro Shift Kit
<a href="http://www.linkedin.com/in/davefortin" ><img src="http://www.linkedin.com/img/webpromo/btn_viewmy_160x25.gif" width="160" height="25" border="0" alt="View David Fortin's profile on LinkedIn"></a>
I used to use WD-40 to clean but the biggest problem I had was that even after you wiped the chain dry, WD-40 would get inside the chain and when you went for a ride to heat up the chain, the WD-40 would fling out all over the place expecially on the tire (NOT GOOD).
I use Chain Clean by Motorex. It works better then WD-40 I think and it completely dries up within 5 mins of you spraying it on the chain.
http://www.motorex.com/index.cfm/fus...1351-1393-1395
I use Motorex Chain Strong lube after I'm cleaning. I like it, it has yet to fling off.
http://www.motorex.com/index.cfm/fus...1351-1393-1397
Just how does chain "lube" lubricate an o-ring chain?
The o-ring keeps the lube for the pins in place, to lube the pin against the I.D. of the bushing, not the surfaces that the rollers contact, {the sprocket teeth and O.D. of the chain bushing}. How much lube is needed for them, I suppose, can be argued. I don't see how not lubing them can be good. Granted, there might not be a lot of rotational movement there, {lots of pivotal}, but there is still is high pressure metal to metal contact. Lube would indeed serve as some sort of cushion.
I don't feel the film strength of any chain lube is worth mucking with the mess. WD-40 and DID take me >15k mi. w/o a problem.
I just picked up some of the dupont teflon lube. I'll let you know how I like it.
+4 for the Motorex 622 strong.
I asked the question when I was starting out and Dave told me to try this.
I just changed out my OEM chain and sprocket ... 20k miles.
It could of gone another 3 to 5k miles but I want to ride this summer,
not work on the bike so I swapped it out.
The rear sprocket still looked good, the chain was a little stretched out
with no tight spots and the front sprocket was starting to look like
sharkfins.
Every Saturday morning before riding, I would clean and grease the chain
and clean the bike with Honda Spray Cleaner and Polish.
This year, I am reversing the front sprocket at 10k miles to see if I can
get longer life out of the chain and sprockets. (steel OEM for long life)
Edit, Yes, I put over 19 thousand miles in a year and two months.
WD-40 works with out a doubt. I have 13k on mine and it looks new and has barely any wear..I dont soak it all i do is spray some on a rag and clean it..Worked so far..
Hells yea kitt. I use the exact same cleaner and lube. It's the best products I've used as far as chain care.
where can I buy kerosene to clean my chain?
