Results 26 to 50 of 57
Chain slack
    Re: Chain slack
    there are people on here that claim 30,000 miles on one chain/sprocket kit when they do take care of it.
    I got about 36,xxx out of mine.
    Re: Chain slack
    I'm going to order the parts right now.. just need to make sure I order the right stuff..lol I've never ordered bike parts before! AHhHHhhh
    Re: Chain slack
    ...and for the love of god, dont buy a clip-on master link for your chain. rivet !!!!
    otherwise, you may end up with this while riding your bike an hour away from home.
    Attachment 14710
    Re: Chain slack
    I'll post up links of the parts before I order just to make sure it's the right stuff for my bike...
    Any recommended sites ?
    Re: Chain slack
    Quote Originally Posted by GreekR1 View Post
    chain
    front sprocket
    rear sprocket
    chain cleaner
    chain lube
    i have ordered several times through solomoto parts, and Dan has very fair prices and excellent customer service. they will ship that over for free, since the total is over $99.
    and i know someone posting on this thread, that would most likely be willing to install it for you for a very reasonable price
    Re: Chain slack
    if you do order from there, there is a drop down for size. just select stock for both sprockets (unless you know your sprockets have been changed like -1/+2)
    Re: Chain slack
    Oh crap, I just remembered Geof did say they were swapped. I THINK he said +1, -2. I also have the stockers. Just looked at them.. decent looking.. just need to be cleaned.
    Re: Chain slack
    Chain 110 or 120 Link?
    On edit....Guessing 110 and remove a few links if I go back to stock?
    Re: Chain slack
    if your teeth have been changed, there is a chance your chain may be a few links too short. the chain needs to be replaced regardless.
    go to that Ace Hardware and get some kerosene (down stairs, 2nd isle). clean those sprockets with kerosene using a nylon brush, but dont leave it soaking. make sure you wear gloves when using the kerosene.
    everyone recommends replacing both sprockets and chain at the same time, for even wear. if those stock sprockets are in good shape, it's up to you if you wanna save $60. check those links i posted. they should be for an 02 TLR with a stock 530 chain using suzuki's OEM sprockets (sunstar).
    Re: Chain slack
    best way to answer that is to count your links on the chain you have. the 120 link chain will obviously cost a few more bucks.
    if you have -1/+2 sprockets, then make sure you have a few extra links on the new chain, than whatever you have now, if you plan on going back to stock.
    Re: Chain slack
    I'll buy the new sprockets. I'll call Geof tomorrow and see what the current set up is so I can stay the same. The chain says max engine size says 750cc which is weird since the search is set for my bike..
    Re: Chain slack
    i originally gave you a link to a 525 chain by mistake, but then edited that chain link. check it again. sprockets and chains have to match up. your bike stock is a 530 chain, so you would need 530 sprockets.
    Re: Chain slack
    <looks over both shoulders>
    Who me?
    Re: Chain slack
    Who me?
    Re: Chain slack
    Have all the stock stuff in the shopping cart but afraid to pull the trigger lol. Not sure if I should go back to stock...ahhh
    Wirelessly posted (BlackBerry8330/4.5.0.131 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    If you like the current setup, stick with it
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Re: Chain slack
    +1, I clean my chain every 300-500 miles and I'm over 10,000 miles and it's no where near being replaced.
    KB KB's Avatar
    Manchester NH
    Re: Chain slack
    If I were you I'd replace the chain and sprockets.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Sep 2007
    Rockland, MA
    Re: Chain slack
    Hi Guys, The chain is fine. I just left a little too much slack when I had the rear apart to install the rear shock. Just needs to be adjusted. When I get back from My current deployment I pan to take care of that for him. I'll probably take care of cleaning the chain as well since I neglected to do that before the sale. sat all winter collecting dust and such.
    <a href='http://militarysignatures.com'> <img src='http://militarysignatures.com/signatures/member6307.png' border='0' alt='militarysignatures.com'/></a>
    Re: Chain slack
    oh he's the guy that bought your bike?
  21. #46
    Re: Chain slack
    i disagree about the chain wax. that needs to be put on a hot chain. use Bel-Ray Superclean. it goes on white so you can see what youve lubed.
  22. #47
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    Re: Chain slack
    do you really need more torque down low with a TL?
  23. #48
    Re: Chain slack
    Quote Originally Posted by brady View Post
    TLs are geared pretty tall, 17/38 or 17/37, my V-strom is 17/41 and even it has a very tall first gear, many people gear them down, just so that slow speed manuvering isn't such a project of slipping the clutch
  24. #49
    Re: Chain slack
    Yup.. Couldn't be happier with the transaction.. I've dealt with a hole sellers before but quite the opposite with Geof.
    Re: Chain slack
    That explains a lot... still trying to figure out taking turns with this bike.
  1. Chain
    Last Post: 06-01-15, 02:34 PM
  2. Chain Slack on 2012 Ninja 250
    By kumpy in forum Bike Maintenance
    Last Post: 03-11-14, 01:10 PM
  3. Replies: 0
    Last Post: 05-03-07, 12:51 PM
    Last Post: 06-29-04, 12:23 AM
    Last Post: 05-28-03, 09:17 PM
