Results 1 to 25 of 38
chain wax brands?
    Posting Freak tonup's Avatar
    Feb 2008
    Alton nh
    chain wax brands?
    I've had enough of the crap I'm using now(Spectro X1). It keeps the chain in good shape but slings everywhere compared to a brand I forget the name of from other years. Anybody have a wax brand that consistently stays on the chain and performs well. Tired of scrubbing and worrying about it being on the tires edge.
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Come visit me if you're near Boston.
    I have about 6 options including 2 chain waxes, clear lube and sticky teflon lube.
    Propper application goes a long way.
    Ray Viernes, Scammer! Ray-Ray's Avatar
    Oct 2009
    Re: chain wax brands?
    Yeah, Duncan Moto has tons of shizznit
    CBR Airlines Flight 1000 Dragginazz's Avatar
    East of Manch
    Quote Originally Posted by tonup View Post
    MAXIMA Chain Wax!!
    Apply AFTER your ride when the chain is warm and 15 minutes later it will be tacky enough to stay in place. The stuff does not fly off and if it does...it's minimal at best!!
    SPEED SAFELY!
    beige camry attack mojobreakfast's Avatar
    Salem, MA
    Motul Factory Chain Lube is great. It is exactly like the stuff that comes on the chain from the factory (ironically). Ted do you carry it? I got my can online.
    no bikes currently
    Quote Originally Posted by Dragginazz View Post
    MAXIMA Chain Wax!!
    I usually clean and do mine right when I get home from a ride so the chain is very warm. The wax seeps into all the areas it normally wouldn't if applied to a cool, chain.
    Chain wax by maxima.... Apply hot and let it cool down then ride no flingn shit every where
    MAXIMA Chain Wax!!
    Add me to the list.
    Used the Maxima product for a while. Tried other products here and there over the years and ended up sticking with the Maxima.
    Hypertarded
    RI / CT border
    Add me to the list.
    or 5 I guess
    just did the chain on the KTM, was looking at the can wondering if anyone else uses Maxima, I guess so.
    Lancaster
    i think motul is what i use
    Corey
    Lifer Currently's Avatar
    Ooltewah, TN
    I have started using the Dupont Teflon dry lube after reading many reviews on it.
    I am impressed ... dries immediately and also makes chain cleaning incredibly easy.
    If loud pipes save lives, imagine what learning to ride would do.
    East of Manch
    I'll have to check that stuff out
    SPEED SAFELY!
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    I've only used Maxima Chain Wax, and have no reason to try anything else.
    Quote Originally Posted by DBKromz View Post
    And Jim's the chain cleaning/lubrication guru.
    Lifer Karaya One's Avatar
    Springfield, Mass
    Motorex 622 Strong. Best stuff out there.
    Check out my eBay store!
    Dave - Motorace - Michelin
    Member smkn-1's Avatar
    manchester
    Bel Ray Super Clean Chain Lube great stuff best i have used
    Lifer R1's Avatar
    Somewhere you dont know...
    Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_0 like Mac OS X; en-us) AppleWebKit/532.9 (KHTML, like Gecko) Version/4.0.5 Mobile/8A293 Safari/6531.22.7)
    Just a tip I picked up.
    As long as the rollers and o rings have a good amount of coverage you can wipe off any excess from the links. This will help keep the gunk down no matter what wax or lube you use.
    Feb 2008
    Alton nh
    Quote Originally Posted by DuncanMoto View Post
    No wheres near Boston unfortunately. Usually spray it after a ride and wipe the excess off.
    MAXIMA Chain Wax!!
    I think that as the stuff I loved. Black, blue and silver label if I remember. I couldn't find it locally and figured wax is wax. I was wrong.
    Quote Originally Posted by Currently View Post
    Never heard of it until now Schweet!
    Quote Originally Posted by R1 View Post
    I usually lube'er up every 300-400 miles. With over 22k and perfect chain and sprocket this stuff I have now is garbage. Have barely used any of it but its going in the trash once I find the maxima again or the Dupont stuff. Bel Ray was my next "go to".
    NESR Rocks. Thanks
    If you're going this route, you may want to read the following:
    http://www.webbikeworld.com/t2/motor...n-chain-saver/
    Ooltewah, TN
    Been using the blue cans purchased at Lowes, just started using the yellow cans.
    It does not pick up dirt, cleaning is a breeze with a K-1 soaked rag.
    No dirt, no greasy buildup around the primary sprocket ... that chore was the determining factor for me to give this a shot. Last time I did it, took almost 15 minutes to get all the crud out from that area.
    Lifer R1's Avatar
    Well all waxes and lubes will gunk up. So proper application will help.
    I just started using lube as opposed to wax and dent do the chain wipe and sure enough it made a huge mess.
    So whatever you use just be sure that the excess is cleaned up and you will be happy with any number of products.
    This is coming from someone who does maybe 2 cleanings a year
    On a side note I hear great things about the Scotts oilers. I may go this route for next season
    I use Motul chain cleaner and Maxima chain wax and haven't had a build-up problem.
    I usually do my cleaning after a ride. Usually between 800-1000 miles apart. I clean per the Motul instructions and with a Grunge Brush. Then spray the wax and wipe the excess.
    The chain is more than sufficiently warm by the time I get to the wax that it seeps in.
    Lifer markbvt's Avatar
    Georgia, VT
    I've been using the blue-can Dupont Teflon stuff for a couple of years now and absolutely love it. It's clean, and it works extremely well. I suspect it's largely responsible for the fact I got nearly 32,000 miles out of the original chain on my V-Strom.
    --mark
    Infected Slyder's Avatar
    Concord, NH
    When the chain warms up again, the chainwax is going to fling.
    I've used it many many years. I switched to the Dupont stuff and after one application / ride...literally chucked the rest of my chainwax. Never again will I put it on anything with a chain.
    I use to hit the chain after a ride or take the bike for a short ride to warm the chain up and let it sit overnight after applying chainwax. Doesn't fly off eh? You should tell that to the counter shaft cover, clutch pushrod, engine case and so on. What a friggin nightmare mess that was.
    Chainwax guys should try it. Wosrt case scenario is you're out 6-8 bucks. Garantee 9 out of 10 of you buy another can of the Dupont stuff instead of chainwax.
    Yes, it's that good.
    Oh...you know how some Alpinestars boots (and many others, I imagine) squeak like hell? Dupont chain saver works well on the squeaky annoying hard armor too.
    Georgia, VT
    Quote Originally Posted by Slyder27 View Post
    Yep -- also works great on kickstand/footpeg/center stand pivots that are a little sticky due to corrosion or whatever.
    --mark
  1. enclosed trailer brands?
    By Paul_E_D in forum General Bike Related
    Last Post: 06-12-25, 10:53 AM
  2. WSB Brands
    By Rada in forum Pit Area
    Last Post: 05-30-11, 05:34 PM
  3. Italian motorcycle brands?
    By Ericthejet in forum General Bike Related
    Last Post: 12-18-08, 02:00 PM
  4. Pics from Brands Hatch WSB
    By Degsy in forum Pit Area
    Last Post: 08-20-03, 10:18 AM
