Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Motul factory for me. Will take a look at the dry stuff though.
After a ride...while still warm...
...first I clean the chain
Then I lube it...
...using the straw to try and only get the lube between the links and not so much on the rollers. Two passes, one on the inside and one on the outside.
Then, as Keith stated a couple times, I wipe off all the excess with a towell.
...Seacoast has a pretty good selection for those in the area!
Muhammad Ali.
Another +1 on the blue-can Dupont stuff; I suspect the yellow can is probably good, too.
I use Motul Chain cleaner, and Motorex Chain Strong (lube). I apply the lube when the chain is hot which is right after a ride. Never have had a fling problem with Motorex.
PJ1 Blue label
08 CBR 1000RR street bike
99 R6 track bike
02 F4i sold to a nesr member
There's a difference between wax and lube.
If you are looking for wax... sweet... that's what i use too. Maxima brand.
http://www.cyclegear.com/spgm.cfm?L1...em=TUC_53-0559
The best advice I’ve ever been given is to not forget where you came from.
related:
http://www.webbikeworld.com/r4/chain-drain/
Just bought one myself a few days ago, so I haven't used it yet.
I heard that the Pro Honda stuff works wonders:
http://www.advrider.com/forums/showthread.php?t=595717
dupont teflon lube, $6 at lowes....no slinging and goes on nice.
