Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Changed Oil/Engine case covers... bike (05 R6) won't start
    so/so mechanic... NeverlosT's Avatar
    Jul 2008
    South Kingstown, RI
    Re: Changed Oil/Engine case covers... bike (05 R6) won't start
    I would think if your ECU isnt happy and isnt dropping the one wire to ground that it would light some indication on the guage cluster (FI or something). If all of the wires are showing continuity (to what, ground? 12V high?) and are not supposed to, it sounds like you dont have a sensor issue, it sounds like you nuked a relay or something and maybe through a heating event merged some wiring. If you get a multimeter, set it to measure voltage, and touch it to each of the 4 wires and see if when trying to start ANY of them change at all. If none of them change, period, then it must be some safety shutoff. Maybe when you got oil on the kickstand sensor it got inside and is constantly tripping the sensor.
    Don't Fake the funk on a nasty dunk.
    NEW STREET/TRACK: 2007.5 Aprilia Tuono
    STREET/TRACK: '08 CBR600RR (SOLD)
    '07 VFR800 (SOLD)
    The Fastest Indian! kamikaze's Avatar
    Jul 2008
    Delhi, Indiaaahh!
    Looks from that diagram like the starter switch supplies the ground to the starter motor through the starting circuit cut off relay (6). Check this relay out or swap it out. The cut off relay needs 8, 9 and 19 to be closed before it will pick. If that relay isn't picked it won't start.
    Let me have a quick look at a real wiring diagram and I can tell you what wires to check. Are you familiar with looking for 12v and continuity with a multimeter?
    Chek for the voltages on the relay end. If the relay is faulty, it will not pick up even if there is voltage. Let me know if you need additional help. I will be around this weekend. I am better off seeing it in person.
    Sold: 1999 Kawasaki ZX-7R
    2005 Pulsar 180 DTSi
    Owning: Pulsar 220 DTSi
    http://www.dhairyagupta.com
    http://bostonbiker.blogspot.com
    Nik viva_brasil's Avatar
    Dedham
    bypassed the switches and still nothing...
    One of the bolts that holds the kickstand switch down got stripped so I just cut the wire off and connected both ends. And I paper-clipped the two inputs to the clutch switch.
    The bike has a gear indicator on it- maybe this could be interfering with the gear/neutral sensor?
    Ignition wiring diagram is on page 378 for whoever can read it and can help... here's the link again:
    http://www.r6central.com/forums/down...ice_manual.pdf
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Fixed.
    You're welcome Nik. Nice meeting you.
    what was it Degs? N switch?
    Nov 2007
    There was corrosion in the killswitch. Needed the contacts cleaned and she turned right over
    Shame on me, I forgot to take high-resolution photos
    Get the correct radiator and you should be good to go, Nik
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Quote Originally Posted by ceo012384 View Post
    Actually, it was the starter switch. Just about 1 ohm across when it was closed, just enough to stop the starter relay from picking. 1 spray of brake cleaner and she dropped to .2 ohms and BINGO!
    Dedham
    thanks Derek for the help and Chris for the hospitality.
    lesson learned: multimeter ftw.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Nov 2007
    You find the right radiator yet?
    LRRS/CCS #103
    Dedham
    yea i did, sent the payment for it today... don't think i'll get to it till after thanksgiving tho since i'm leaving friday for my week off.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
  1. CBR600RR 03-06 Woodcraft Case Covers
    By Io-bot in forum For Sale
    Last Post: 09-11-12, 06:44 PM
  2. Replies: 9
    Last Post: 06-09-10, 08:28 PM
  3. Case covers/guards
    By gixxer72 in forum Pit Area
    Last Post: 03-10-10, 03:30 PM
  4. Case Covers for tech?
    By JRide in forum Pit Area
    Last Post: 06-05-09, 09:06 AM
  5. ZX6R Case Covers?
    By scootertrash in forum Pit Area
    Last Post: 08-17-07, 10:59 AM
