Results 1 to 20 of 20
More SV issues
    Lifer Pittenger5's Avatar
    Austin
    More SV issues
    So on the SV, 2001, 1st gen, when sitting at stop lights every now and then theres just a big clunk from the engine. Its somewhat common, but not consistent enough that I can narrow down where its coming from. I think it only happens in neutral, cant really feel it when riding, but that might just be masked by the sheer unadulterated joy I get from riding that bike. I know a clunk from the engine is extremely descriptive, I tried searching online, and it seems to be a common ailment, just wondering if anyone has experience with this, and or how to fix it.
    Zip Tie Alley #505
    Re: More SV issues
    Misfire clunk? Engine ping? Detonation?
    Do it with the clutch in while in neutral?
    Dublin, NH
    Re: More SV issues
    I used to hear the same thing on my 1st gen SV650. I always thought it was just just the "thumpiness" of the twin, but maybe it really is a problem. But mine only happened when it was cold.
    2023 KTM 890 Adventure R
    Austin
    Re: More SV issues
    Neutral mostly, clutch too I THINK. But like I say, I only notice it at stop lights, and 90% of the time Im in neutral.
    Zip Tie Alley #505
    Roslindale, MA
    Re: More SV issues
    Fueling issue? You sync the carbs??
    Lifer golden chicken's Avatar
    Attleboro, MA
    Re: More SV issues
    Someone on SVRider just had an issue with his bike backfiring. His throttle bodies were loose against the intake tubes, causing a large vacuum leak.
    Here is the thread: http://www.svrider.com/forum/showthread.php?t=156006
    Austin
    Re: More SV issues
    Ehh, nothing like that. The best I can describe it is when you kick the bike back into first from neutral. That nice thwack with enough force to make you feel it through the bike. But its never popping into gear or anything, just that kind of noise/feeling.
    Zip Tie Alley #505
    Roslindale, MA
    Re: More SV issues
    sounds like your just not used to a clunky gearbox.
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Re: More SV issues
    I have a similar issue in my 2000 sv.
    Not consistent at all. Almost feels like a misfire to me in the front cylinder. I replaced the coil and plug wire. Still does it intermittenly.
    Roslindale, MA
    Re: More SV issues
    Man, these SVs sure do have alot of problems....
    Shoulda got a Ducati!
    Re: More SV issues
    Clean up all your grounds and solder all electrical connections from the battery/grounds/etc.
    Vmax did that until I make it easier for it to toss a spark.
    Jul 2005
    Bennington, NH
    Re: More SV issues
    Mine does this. I never thought of it as a problem.
    Or do you mean it makes that noise when you are NOT doing that? Cause that's weird.
    Lifer obsolete's Avatar
    Norf Sho
    Re: More SV issues
    What connections were you recommending to solder?
    Mine used to do something similar at low speeds when using a lot of clutch. Got rid of the air injection and it cleaned up.
    -Alex
    Re: More SV issues
    Any that supply power to the ignition. Including the crimp on the battery leads (both ends), going to the coils, etc.
    Helped my Max out tremendously. Now she's smooth as silk even with the cooling fan on in traffic.
    Norf Sho
    Re: More SV issues
    Do you mean solder the connections together and bypass connectors or the wire to the connector.
    -Alex
    Re: More SV issues
    Anywhere there is just a crimp connection, flow some solder in there. Wire to connector.
    Lifer Currently's Avatar
    Ooltewah, TN
    Re: More SV issues
    Chain has too much slack.
    How many miles you have on that chain?
    If loud pipes save lives, imagine what learning to ride would do.
    Re: More SV issues
    Quote Originally Posted by Currently View Post
    Clunk from the engine when he's sitting at a light in neutral, and you think it's his chain???
    Wat?
    Austin
    Re: More SV issues
    I dunno man, I think its your rotator splint.
    Zip Tie Alley #505
    Norf Sho
    Re: More SV issues
    I'll rotate your splint.
    -Alex
  1. CBR issues
    By gixxer72 in forum General Bike Related
    Last Post: 06-20-17, 05:59 PM
  2. 02 SV issues
    By SVRACER01 in forum Bike Maintenance
    Last Post: 07-10-13, 07:58 AM
  3. WTF wap issues!!!!
    By R1 in forum Site Info & Suggestions
    Last Post: 07-29-10, 09:15 AM
