I usually put in fresh oil in november, pour in some stabil into the gas and run it through, and leave a battery tender on it. She gets ridden all year. Rarely sits for more than a few days at a time.
WARNING: You may be exposed to irony, to wit: an utterance marked by a deliberate contrast between apparent and intended meaning; Please do not overreact. Only objects in the rearview mirror are larger than they seem everything else is just as you thought it was.
https://motorcycleinfo.calsci.com/Consumables.html
We use Rotella T6 Synthetic in many vehicles. You can buy 5 quart jugs at Wally.
You can spend as much time as you like on BITOG.
https://www.bobistheoilguy.com/forums/
I have approx 10 gallons of T6 I got with coupons. I use it in everything but new lawnmowers. Lawnmowers with a single piston ring are very sensitive to oil weight. Great for M/C's. No friction inhibitors to affect the wet clutch.
JASO specs: https://www.oilspecifications.org/jaso.php
So an 18 year old thread got revived just to post a meme? Odd.
