Has anyone ever assembled a bar weight like this?
I did it last night, I was however unable to get part the weight into the clip-on with part #12 attached.
It's a metal rod with a rubber ring at each end, it appears to be a vibration damper. #12 is a metal retention clip.
Every time I tried to press the assembly in the rubber ring would deform and the retention clip would pop partway back out.
I'm not particularly worried about anything coming loose.. I almost question the need for the entire thing.
Pull that crap out of your bars and get te kind of bar ends that have the rubber that expands into the clip on holding it in. DONE!!!
