Results 1 to 10 of 10
fork spring change
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    fork spring change
    ok, some racetech .95kg springs are in the mail for my gsxr front end on the sv. i found them cheap on ebay, so im not sure if they come with all the neccessary hardware...but hopefully they do.
    does anyone have experience with swapping these springs? they are 05 gsxr 750 forks. im guessing i would
    -remove top fork cap
    -compress the spring via spacer with brute strength or spring compressor
    -remove top cap by loosening jambnuts
    -remove spacer
    -remove spring
    -put new spring in
    -put same old spacer in
    -drain oil, set new oil height (7.5wt) with springs in, and upper tube all the way slid down. (or all the way up?)
    -bleed by pumping forks
    -install top cap
    basically, will i need different length spring spacers? and do i need to remove the bottom bolt holding the cartridge assembly to change fluid?
    thanks for any help.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
    Derry NH
    Re: fork spring change
    Standard forks?
    Everything you said sounds right. The springs don't come with any hardware, you reuse all the factory parts. No parts needed except the springs and fluid.
    Apr 2010
    Georgia, VT
    Quote Originally Posted by Eric Baker View Post
    Standard forks?
    these are USD forks, not traditional style if thats what you mean by standard?
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    If they are single chamber forks, then what you wrote is correct. No need to undo the bottom bolt to swap springs.
    Apr 2010
    Georgia, VT
    single chamber....hmmm. not sure what that means.
    how about for draining/filling/bleeding oil?
    also, do i measure oil level with forks completely extended, or with upper tube completely slid down? ive worked on forks occasionally, but my memory is foggy.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    They are likely single chamber. Filling/measuring oil is done with the spring out and check the manual for what point of extension to measure from. find a forum with a suspension guru and ask there, lol!
    Apr 2010
    Georgia, VT
    thanks, ill search around.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    Posting Freak
    New Hampshire
    set your oil level with the fork compressed, spring out. (after you've bled any air out of the cartridge)
    Apr 2010
    Georgia, VT
    So, update.
    I got the springs I bought on eBay. The dude said they were racetech 9.5's, even sent me a pic of the box. However, when I got them, they look identical to the stockers in every way. I even went as far as swapping the springs into the forks, and compressing them with my body weight...they compressed the same distance and felt the same rate. Guess you get screwed sometimes on the Internet, I accept that. The springs did come with a ton of washers the dame outer diameter of the springs, as if they were meant to stack in there to preload the spring. Weird. My guess is the box was from what the dude put in his bike and then put his old ones in the box. Fucker.
    Could I be wrong here? I guess I'll just order some from a reputable company and try to get my money back on the others. Oh well.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    Derry NH
    It's been a while, but I remember my springs looked identical to stock. Only way to know for sure is to test them or have them tested. It's nearly impossible to tell the difference just by feel.
  1. Fork oil change
    By DaveZX6r in forum Bike Maintenance
    Last Post: 05-07-12, 10:35 AM
  2. KAWASAKI ZR-7 - 2000 - SHOCK & FORK SPRING
    By Polonius in forum Wanted
    Last Post: 01-04-12, 01:08 PM
  3. Fork Spring Compressor
    By Es_617 in forum Bike Maintenance
    Last Post: 03-02-11, 09:56 PM
  4. 50mm fork seal change
    By peeP in forum Bike Maintenance
    Last Post: 05-08-10, 10:01 AM
  5. My first ever fork seal change
    By CB750F in forum Bike Maintenance
    Last Post: 05-06-09, 05:52 AM
