05GSXR75005SV65090DR350
I think I got mine at Autozone?
Yeah, like less than $40ish seems right.
Of course I don't know why you'd want to replace one.
Just test the one you have. If it works, keep using it.
Have an old HF one that I only used a handful of times, but tried on multiple running bikes and only ever hits 35-40psi.
Try replacing the Schrader valve in the hose first. It should be the same as any tire valve stem.
I like my OTC Deluxe. Can be had for $66ish, or the basic one for $55ish.
You get better results if the bike isn't running![]()
The Schrader valve in the hose may be either hanging open or clogged with crud. They're a special low spring pressure design so the compression pushes it open. NOT a tire valve core.
I use an OTC 5604, but they're closer to $95 than $40. No experience with the Pit Posse. Lisle is generally good, but the attached hose and extra purchase adapters are weird.
*scooped by chicken while looking for the part number.
yeah $40ish is what I spent too...just went on amazon and got the one with the best blend of reviews/price for the 2-smokah
I just put my thumb over the hole, if it pushes it off, good to go.
Yeah, I bought one at autozone as well.
I also have an OTC kit. And it works well.
Be ware that for bikes you want the OTC 5604 kit Doug mentions. Not the OTC 5605, like I bought. The 05 kit has different adapters and doesn't work as well with deeply recessed plug holes.. like those you find on OHV engines.. which almost all motorcycles are. I make the 05 kit work, but get the 04 kit instead.
I spent closer to $70.
i have a brand new, unused, INNOVA 3612 comp tester i can't use due to space issues on the RR. the adapter is too long, i can't fit it under frame.
if you're interested, let me know. i'd be good with shipping + 2 bucks for a roadie in return (?)
Actually I pulled the trigger on that OTC 5604. Looks pretty solid, exactly what I need, and hoping I'll have it in the toolkit for a lot of years.
Thanks guys
wth is a roadie anyway? Asking for a friend
Satisfied! Nice little setup.
Hey, you shouldn’t eat Tide pods and drive man!
