Page 6 of 6 FirstFirst 123456
Results 126 to 147 of 147
Countershaft issue
  1. #126
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: Countershaft issue
    Why? I have a girl, I dont care how ugly I am anymore.
    touche...
    LRRS #399
    MX #505
  2. #127
    Jun 2005
    I don't want my post to be taken as I think it will be an issue. I'm just curious about how the physical forces whould opperate and what would change the reaction of the materials. I'm just a curious fella.
    Yeah, that's totally the way I took it too. It's all good, Joel.
    I hadn't really thought about it to be honest. It's interesting. The OD of the bolt is about .0015 larger than the ID of the hole I stuffed it into. What happens to that .0015? Does the bolt compress? Does the shaft expand? Both? To what extent? Is it like a matter is neither created nor destroyed kind of thing? Help us baby Jesus. Help us Tom Cruise.
    Lifer Pittenger5's Avatar
    Austin
    Same place as that sock that gets lost in the dryer.
    Zip Tie Alley #505
  4. #129
    Jun 2005
    Fucking asshole sock and .0015 hanging out... drinking Zimas... laughing at us.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Hey I hate that place...
    Posted by Jane in BoxChat
  6. #131
    Lifer obsolete's Avatar
    Norf Sho
    Do you think the strength of the material is a bigger player than the actual angle and shape in which the force is applied? I would think a ring expanding would require less force than a cylinder being compressed. But does a hardened steel ring resist deformation more than a stainless cylinder? What if they were both the same material?
    Just kinda where my brain was going with that, but unfortunately I do not have the knowledge in physics nor metallurgy to answer them myself.
    -Alex
  7. #132
    Norf Sho
    I'm thinking that if material are the same then it is easier to expand the structure of molecules than it is to comrpess them in on themselves and there for the ring accepts the difference.
    Fucking zima drinking socks!
    -Alex
  8. #133
    Jun 2005
    Yeah my monkey brain agrees with the easier to expand than compress logic. I tried to ask the question on a machinist forum and was dumb enough to post the background of why I was asking... got 10 different guys offering 10 different ways I *should* have done it. Only one actually tried to answer the question.
    Norf Sho
    So... How should you have done it?
    -Alex
  10. #135
    Austin
    Sounds like NESR?
    Zip Tie Alley #505
  11. #136
    Sounds like NESR?
    Did you check the brakes?
    It would be Best to Remove The chain and wipe it down with Murrays oil soap and to ride the bike without pants
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
  13. #138
    Nov 2007
    Quote Originally Posted by BLACK SQUIRREL View Post
    perfect
    Zip-Tie Alley Racing
    LRRS/CCS #103
  14. #139
    Jun 2005
    Apparently I should have used my $60,000 EDM machine to cut internal threads into the hardened shaft. I feel silly, really... I mean, it's so obvious. Everyone has EDM capabilities, right?
    Austin
    I thought you were Tricky Mike? You cant build one of those out of some rebar and duct tape?
    Zip Tie Alley #505
  16. #141
    Norf Sho
    Is that the one that uses the wire thread under water? My buddy has one lol.
    Would there have been any way to thread it on a lathe or does the hardened metal negate that possibility?
    -Alex
  17. #142
    Feb 2007
    CA
    O man, why didn't you say you needed one of those! I would have loaned you the one in my bathroom...
    All joking aside though, there are standards you could by if you wanted to for press fit but again richies bike shouldn't blow up (from this mod)
    LRRS #399
    MX #505
  18. #143
    Considering removing the threads from two holes in a cheap, chinese counter shaft sprocket could toast a brand new carbide burr, I can't imagine a thread cutter that'd last two rotations against that shaft.
    Lifer lrrs313's Avatar
    Asheville, NC
    Wirelessly posted (BB Tour: BlackBerry9630/4.7.1.61 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Obviously these guys don't realize that this is a dirt bike at heart not a frickin MotoGP bike. Tricky, that looks good to me. Probably quite a bit better than anything I would have done. Should work just fine.
    -Brian
    15 S-Works Venge
  20. #145
    Nice work, looks good.
    Jun 2005
    I didn't machine any anti-punt into it... so should you decide to return to the world of road racing on dirty bikes (please, please )you should be able to fuck up Richie's chi as usual... You just might have to go to FL to do it, though
  22. #147
    Jun 2005
    Exactly. A carbide auto center punch left no mark at all. That was as far as I pursued threading it... A big part of that decision was the fact that I would have had to fabricate the tooling to cut the threads on the small 8mm+/- ID of the shaft. None of my carbide stuff would fit in a hole that small. I know... that's what they all say.. I'm not opposed to machining the tooling. It works just fine for ALU, brass, mild steel, etc... I just thought it would be a waste of time for this shaft. Way too hard.
  1. my first issue..... Help!
    By P_easy in forum Bike Maintenance
    Last Post: 09-11-09, 08:00 AM
  2. countershaft sprocket seal leak
    By chief929 in forum Bike Maintenance
    Last Post: 04-28-08, 06:12 PM
  3. Love me some countershaft nuts.
    By JeffL in forum General Bike Related
    Last Post: 08-10-07, 10:38 AM
  4. front sprocket/countershaft question
    By trackdog in forum General Bike Related
    Last Post: 08-05-04, 09:28 PM
