Results 1 to 25 of 30
Draining coolant reservoir
    Lifer Pittenger5's Avatar
    Austin
    Is there some easy way to drain this damn thing, other than take the whole thing out and dumping it upside down? Maybe just syphoning the fluid out through the fill hole (giggity). All I know is when I drain the radiator theres stioll water left in the reservoir and I cant figure out some seemingly simple way to get the shit out, so am I retarded, or is there no easy way (and in this case its not a multiple choice answer).
    Zip Tie Alley #505
    Meriden, Ct
    Re: Draining coolant reservoir
    What bike?
    Austin
    All of them, but my EX and my 636 both did the same thing. Just seeing if theres something Im missing.
    Zip Tie Alley #505
    Nov 2007
    Richie just take the reservoir off... it's like two bolts eh?
    There is also often a little bit of crud in the bottom so I take the thing off, drain it, clean it out with hot water, etc.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Austin
    The EX is easier than my 636, but even its a pain in the ass to get to the bolts. Gotta take off the tank, get into the bolts, get the hoses off, etc. I just thought there might be an easier way.
    Zip Tie Alley #505
    Nov 2007
    well in that case if you don't mind not cleaning it just use a siphon you can find one for like 10 bucks... or suck it out and try not to get it in your mouth
    LRRS/CCS #103
    Foxboro, MA
    siphon on the 636, PITA to unbolt - this time dont swallow though pitty - you will go blind
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Austin
    Joel with that much shit Id really think about figuring out how to get it off and clean it out well.
    I had a LITTLE in mine last year, and I used a mityvac to drain it, and just refilled it with water and drained it a couple times, seemed to get most of the crud out.
    Zip Tie Alley #505
    Austin
    Quote Originally Posted by Crash Dummy Denno View Post
    Why, I'm legal on my EX, its only water.
    Im not gonna drain the 636. but Ive done it in the past, and things worked the same way, just used that as an example.
    Zip Tie Alley #505
    Nov 2007
    I have to do mine... drain out all the engine ice and go to distilled/wetter
    edit: speaking of that if someone wants the ice i will hook them up, i've only run it for like a thousand miles (all track though)... i have about half a jug of fresh stuff, and then a jug and a half in the bike that is still fine to be used. that shit is expensive so i'm not gonna toss it or anything
    LRRS/CCS #103
    Foxboro, MA
    read your 1st post - i have no idea what bike or why you're draining
    2006 Yamaha R6
    Sep 2006
    Around the corner
    Why do you need to do this DB?
    The rule is:
    Austin
    Quote Originally Posted by ceo012384 View Post
    drain out all the engine ice and go to distilled/wetterg
    You can leave engine ice, cant you?
    Draining water in the EX to put in antifreeze, but it was more of a general question, not necessarily bike specific.
    Quote Originally Posted by The Crashing Tomato View Post
    Drain the water to put in anti-freeze.
    Zip Tie Alley #505
    Sep 2006
    Around the corner
    why not just add A-F (the uncut stuff ) it will dilute itself in the pouring process and walaaa no sucking
    The rule is:
    Austin
    Well, that is an option, but I have diluted stuff, and then the problem would just arise next spring when I need to drain the anti-freeze anyway. But that might become an option now.
    Zip Tie Alley #505
    Senior Member Hoss's Avatar
    Southern, NH
    Quote Originally Posted by l3uddha View Post
    i'm in the same boat. i can't even see where the heck the bolts are on mine. all i can see is about an inch of crud at the very bottom of the reservoir.
    Joel, is that for the 675? If so, the tank has to come off as the bolts are on the inside. While you're at it search over on the 675 forums for the size of the fittings to replace the plastic elbows on the 675. They are known to crack and dump coolant. And in a few cases all over your rear tire.
    And no...no recall.
    2006 Triumph 675
    2002 Yamaha R6 Track Bitch
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    your radiator overflow reservoir doesn't have a nipple/hose on the bottom?
    Austin
    Does, but at that point itd be just as much work to unhook it and drain it easier.
    Zip Tie Alley #505
    LRRS Rider #256 QuarterGig's Avatar
    Gorham Maine
    has anyone used rv antifreze to store their race bikes or one of the non-toxic ones so disposial is not as much of an issue?
    Seth
    LRRS/CCS NV #256
    2007 Ducati S2R1000 Street
    2000 Triumph TT600 Track For Sale
    1984 Honda Magna needing reassembly.
    1974 Honda CB 750 needs wiring
    1974 Honda CB 350 needs engine work
    DB, you don't need to drain the resevoir... it's plastic, it's gonna crack. Just pop the drain plug on the water pump & drain the radiator & the block.
    If you wanna get rid of the crud on the bottom of the resevoir then just pull the hose off the bottom & spray a hose in the radiator to stirr it all up and flush it out the resevoir drain hole.
    Austin
    Quote Originally Posted by QuarterGig View Post
    Disposals no issue for me, I have a storm drain right in front of my house.
    Zip Tie Alley #505
    Austin
    DB, you don't even NEED to drain the resevoir... it's plastic, not like it's gonna crack. Just pop the drain plug on the water pump & drain the radiator & the block.
    Well if you wanna get technical, my bikes in a semi-heated garage, I dont need to drain anything.
    But Id rather just be safe.
    Zip Tie Alley #505
    ninja edit above.
    Gorham Maine
    yes you live down there.. up here in Maine we are trying not to pollute the world.. and i would prefer not to kill my pets by dumping it in the yard
    Seth
    LRRS/CCS NV #256
    Austin
    Well that works well for me, I dont have any pets. I think the antifreeze killed them.
    Zip Tie Alley #505
  1. Draining front brake fluid
    By Garandman in forum Bike Maintenance
    Last Post: 04-29-19, 11:03 AM
  2. Draining coolant before freeze
    By Petorius in forum General Bike Related
    Last Post: 10-15-13, 07:04 PM
  3. WTB: coolant Reservoir cap for the 06 gsxr 1000
    By duganc1717 in forum Wanted
    Last Post: 07-08-11, 02:32 PM
  4. Draining Water...
    By Stoneman in forum Pit Area
    Last Post: 11-10-03, 06:19 PM
