Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Ducati S2R1000 - barely runs and runs rough
    Member Fitron's Avatar
    Mar 2016
    Winchendon, MA
    Re: Ducati S2R1000 - barely runs and runs rough
    Do you have experience with this pump? Not much info online and no website either.
    No sir I do not. Just figured that for 30$ you can't really go wrong...if anything it will help diagnose your problem.
    I just bought a $50 fuel pump on Amazon. Went for a slightly higher quality one than the $30 pump. Works great.
    Apr 2011
    NH
    I bought a cheap-30-50 pump on ebay or amazon, I can't remember and I can't find the info but I has been fine for 2-3 years now.
    It looks like the same exact thing I pulled out of one of my cars. same size, same electrical connector, same fuel line hookup, same damn thing. They come with crap you don't need like that sock filter and maybe an electric connector but you just throw that stuff in the tool box for later projects.
    oh yea, it may not clip into the stock sending unit. The stock pump was longer so I had to use a hose clamp to secure the pump. no big deal.
    Tim
    LRRS #44
    Superbike Services 44
    Apr 2011
    NH
    I just watched your video.
    You'll have to look at you bike but you typically can't do a pressure on the return hose. You need to figure out where the pressure regulator is but it should go pump, filter, injectors pressure, regulator, tank. Wither that means the regulator is next to the injectors like my 01 monster, 01 748 and I'm pretty sure my 749 or in the tank I don't know. If you test after the regulator you will have very little if any pressure. The flow is still low(i was waiting to see it spray into that container and back out again) and I'd still get a pump.
    Tim
    LRRS #44
    Lifer SwiftTone's Avatar
    Norwood, MA
    Quote Originally Posted by timmyho414 View Post
    The system is in the order you listed but the regulator is in the tank so the fuel goes through the regulator after the return hose.
    Can I remove the fuel pump unit and test the flow with distilled water?
    Apr 2011
    NH
    I wouldn't run water through it.
    If the regulator is in the tank like you said and the hose in the tank are all okay like you said then your test was valid and the pump is bad.
    Being that you replace the filter because of a running issue and everything else looked ok in there it sounds pretty solid that the pump was the root cause.
    I'd put a pump in it and do your test again to verify you have pressure and recheck the flow. You should be all set.
    Tim
    LRRS #44
    Apr 2011
    NH
    you know the more I think about this you may want to T into the return line with the pressure gauge so the regulator is in the equation once you get the new pump in. Otherwise the pressure will/may show too high and may freak out the new pump.
    Tim
    LRRS #44
    Norwood, MA
    So….its running!
    Took the tank back off and did a fuel pump flow test with the new Ducati filter and the old NAPA looking filter. Noticed that the Ducati filter flowed less water. Installed the old filter back on and was able to build pressure to 43psi after priming a few times. It fired up immediately! Went to NAPA and bought a 3032 Gold filter, installed it and same pressure characteristics of the old filter.
    I can’t believe the culprit was the Ducati filter.
    Admittedly, I did buy the new filter from eBay to save a few bucks, but from a highly rated seller. I would have never thought a new filter could be bad. Lesson learned.
    Thanks all!
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    It was probably thrown around during shipping so many times that the filter element turned into a solid mass of blockage.
    Lifer golden chicken's Avatar
    Attleboro, MA
    I wonder what about the filter caused that...
    Lifer Not Sure's Avatar
    NH Seacoast
    David, you should have just replaced the filter to begin with and saved yourself a bunch of trouble.
    Lifer gumby's Avatar
    NH
    A test ride to VT is in order.
    go faster cdovego's Avatar
    Weymouth
    glad it's sorted - good work!
    Central Mass Powersports #123
    Norwood, MA
    Who would have thought that a simple part like a fuel filter would be bad out of the box.
    Canada. CANADA! You coming right?
    Not quite yet. Stay tuned for the next episode...
  1. gsxr runs like shit under 6k rpm
    By G21forme in forum Bike Maintenance
    Last Post: 07-07-08, 02:57 PM
  2. $10 Dyno Runs!!!!
    By motorcyclenight in forum Motorcycle Night - Lowell
    Last Post: 08-14-06, 09:06 PM
