Results 1 to 19 of 19
Frame Slider Install
    Work U HBerry's Avatar
    Nashua
    My buddy needs some help drilling a hole in his plastics to install his left frame slider on an 05 ZX-6R. Anyone interested in helping? He'll give you a 6 pack of Sam's for the help.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Lifer legalspeed's Avatar
    Somersworth, NH
    Get some Pay-doh. Stuff a wad on the inside of the fairing about where the bolt and slider would go.
    remove OEM frame bolt and replace with extended slider bolt without the slider attached. Do NOT screw in the extended bolt all the way; leave enough out to make an impression in the play-doh. Replace the fairing and push into the bolt to get the location in the play-doh.
    Use a hole saw and cut from the inside out.
    I would suggest using a hole saw that is at least 1/8" larger than your slider. I went 1/4" larger and have never regreted it.
    -D
    LRRS\CCS\WERA #486
    Nashua
    Unfortunetly, knowing his and my luck, we will likely cut his fairing in half.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Somersworth, NH
    Zip ties my friend....
    It's a piece of cake really. He's already made the good decision and passed on the brackets.
    Where is he at?
    LRRS\CCS\WERA #486
    Nashua
    NASHUA!
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Nashua
    ANYONE??!!
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    the '05's require drilling???? i thought the engine mount was right there by the side venting like the '03 and '04?
    Nashua
    Nope its behind the fairing on the left side. Mine were easy.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Somersworth, NH
    If you can't do it by next weekend, and will pay the gate fee ($20 Sunday, 10 if GMD has some grandstand passes) and I'll do it beside our pit.
    It will take me 10 minutes.
    LRRS\CCS\WERA #486
    Bring it up to Center Barnstead? I'm not DOING it, but I'll show you clowns a real simple way and coach you through it as YOU GUYS do it...
    Nashua
    Well yes, you coaching and doing it for us should work out the same. If it were my bike, I would be more willing to dremel it, but sense its his, Im a little more cautious (sp?)
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Somersworth, NH
    -D
    A hole saw is not a dremel. Do NOT dremel your fairings.
    LRRS\CCS\WERA #486
    Nashua
    Sorry, thats what I read on those crazy kawiforums
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    My method is pretty much the same as legalspeed's. Only I use dirty grease on the bolt/slider in question to mark the inside of the fairing...
    Remove fairing / install slider / smear dirty grease or chain lube (just get it from your chain) on the head of slider / GENTLY fit fairing on (just enough so the grease/lube marks the fairing) / remove fairing & drill with SHARP, FINE TOOTH hole saw...
    I'd suggest going 1/4" larger (diameter) on the hole 'cuz it'll give ya 1/8" of playroom around the entire slider. He'll appreciate that when he tries to remove & replace his fairing...
    Lemme know if ya wanna bring it up and I'll walk ya through it...
    i was very technical with mine. I put the bike on the rear stand with body work off and measured with a yadrstick to the center of the bolt head. Then put bodywork on and used previous measurments to mark bodywork and drilled a small hole first (double check my work) and then holesawed away. And yes go a little bigger on the hole
    Nashua
    if the weather is nicer next weekend we will likey ride up and see you my friend.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Hmmmm...let's make better plans for this. I don't think I'll be around Saturday. Sunday's lookin' like I may be around in the afternoon though...
    Nashua
    Scratch that, I have to work next weekend at school so no good. We will have to work on something for the weekend after.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
  1. Any Frame Slider Installers out there?
    By virtualbong in forum General Bike Related
    Last Post: 07-04-06, 09:28 PM
  2. frame slider question
    Last Post: 06-08-06, 07:39 PM
  3. Frame Slider Recommendations
    Last Post: 02-15-06, 05:44 PM
  4. Frame Slider Material- Where to buy?
    By McBiggity in forum General Bike Related
    Last Post: 11-04-05, 04:01 PM
  5. No Cut Frame Slider?
    By MnM in forum Bike Maintenance
    Last Post: 07-17-05, 11:05 AM
