Do you use it on front and rear, or at all? and what color? Thanks
YES on just about everything.
Blue at a min.
green as a max
I use Blue and Puple for light duty........
LRRS EX 66
factoryeffex
Thanks guys. I found a lot of mixed info so I wanted to ask. I'll be installing my new Stealth Sprocket set up this weekend.
I had 2 sprocket bolts loosen up on me. I was cleaning up some chain lube and was shocked to find one backed out a little and another was not near torque spec. From then on they see the Loc.
I just put red loctite on those and rotor bolts etc
LRRS #399
MX #505
I don't think I put loctite on the cush studs, but then again the sprocket nuts on my bike are locknuts...![]()
Zip-Tie Alley Racing
LRRS/CCS #103
No...but thinking I will now....
great question
(am I confused or have I seen some of these actually safety wired?)
Muhammad Ali.
I safety the front sprocket. It has 2 bolts that usually no taper to them. Ease of drilling.
My rear has taper to the bolts so not as easy to drill. + you would eat up a lot of safty wire and time making sure every thing is just right.
All my fronts had bend over safety tab so no
Otherwise yes I recommend it
Glen Beck is John the Baptist
safety wire on the rear bolts? geez, might as well safety wire the gas cap to tank and wire the tires to rims![]()
LRRS #399
MX #505
I actually lied I do use loctite on the countershaft sprocket.
I know red loctite is called for on sprockets on dirt bikes. Once they come loose you can throw them out as they will never stay tight again. They get ruined in a hurry. Same goes for a shift bolt, but i only use blue on thet.
OT
It pays to play.
Ride fast,
You will get farther before it is over!
