Results 1 to 15 of 15
Right Front Turn signal won't blink
    Portsmouth, NH
    Hi, the right front turn signal on my bike has stopped blinking. when you use the turn signal switch the light on the dashboard stays green, the rear turn signal blinks properly, but the right front is dead. I checked the bulb, and the bulb is fine. The wire that connects to the bulb socket is connected, but I don't have a multimeter to see if it's hot. Any ideas?
    atek3
    Littleton, Ma
    Re: Right Front Turn signal won't blink
    Quote Originally Posted by atek3 View Post
    atek3
    connection from wires to socket or socket to bulb. does the rear blink faster or is it still at the same speed?
    I'm sorry... did you read ANYTHING besides the title of the thread?
    Quote Originally Posted by REDVTR1000 View Post
    Littleton, Ma
    he said nothing about socket to bulb connection. the wire to socket could be fine on one end but not the other and on some the wire to carrier connection can not easily be seen. i asked about the turn signal because because i didn't know what he meant by normal. the fact that it blinks at all can be considered normal. i was just offering to help. guess it is not needed.
    mine went out the other day, and it was a loose ground connection. i use male-female connectors from the directional to the factory wiring. somehow, the ground in the male connector got loose. i re-crimped it and used heat shrink around the connector & it's been fine since.
    not really sure how far you are from me, but i could give you a hand over the weekend if you're still stuck
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    fuck it... 3 lefts equals a right
    complainers i tell ya
    jk
    Lifer R1's Avatar
    Somewhere you dont know...
    If you ask me this thread has not made any change of direction at all therefore its gone in a straight line
    down hill!
    Like jim said check your grounds..... the more of a chance that there is any corrosion the more likely it is that the connection could just be loose.....
    trust me corrosion can fuck your shit up. I would tell the story about a guy i knew who replaced the starter in his truck and it turned out to be a bad connection with the battery, but ill refrain from telling that story because its irrelevant.....
    funny but irrelevant
    btw this post also helps with the intended direction of the thread.......
    Quote Originally Posted by R1slowflyer View Post
    fuggan R1slowflyer. he neglected to note that he forgot to check the battery terminals on that truck as well as the person who swapped out their starter
    Lifer R1's Avatar
    if you ask me it was one big cluster fuck to begin with....... You have to admit its still pretty damn funny.
    atek, let me know if you're still stuck over the weekend. i'm going to try to help out as many people as possible to steal Keith's thunder from his help thread(s)
    Lifer R1's Avatar
    LRRS Rider #256 QuarterGig's Avatar
    Gorham Maine
    i am thinking you need to replace the whole wireing harness.. prolly let the smoke out of the wires some how..
    seriously i agree with checking for corrotion on the ground... might be worth it to give a quick scrub to all those connections with a green scrubby
    Seth
    LRRS/CCS NV #256
    2007 Ducati S2R1000 Street
    2000 Triumph TT600 Track For Sale
    1984 Honda Magna needing reassembly.
    1974 Honda CB 750 needs wiring
    1974 Honda CB 350 needs engine work
    Portsmouth, NH
    thanks for the advice y'all, i'm going to try to find a multimeter so i can find the problem.
    atek3
    Lifer R1's Avatar
    seriously all joking aside i have multimeters if you need.....
    atek3
    i withdraw my offer for help when you said "y'all". sorry, it's my personal policy. K-man, he's all yours for the assistance call
  1. Wanted - Parts & Tools | Front Left Original Turn Signal for TL1000S/R, SV650 or GSXR750/600
    By Garrett in forum Wanted
    Last Post: 07-05-19, 10:53 AM
  2. WTB: 95 GPZ front turn signal
    By chris275275 in forum Wanted
    Last Post: 04-20-11, 09:09 AM
  3. Replies: 14
    Last Post: 10-06-08, 01:59 PM
  4. Turn signal woes
    By Zolden in forum Bike Maintenance
    Last Post: 06-05-08, 09:18 AM
