Results 1 to 25 of 31
Another stuck oil filter...
    Nik viva_brasil's Avatar
    Dedham
    So my oil filter is stuck, it must have been put on way too tightly and no oil on the seal...
    It's a round type (K&N I believe) with a 17mm nut on the end- the nut is stripped.
    I bought a filter clamp tool- it just dented the filter and it didn't budge. Trying to bend the handle on the tool so I can fit a closed wrench over it for more leverage. Don't have clearance for a pipe (the handle is pointing downwards since that's the only way the tool fits).
    I also got a BFH and hammered a screwdriver through it, but broke the screwdriver in the process of trying to twist it off. But, my tools are pretty cheap (task force)- so I pretty much expected the screw driver to break.
    If anyone has any suggestions please post. I'm thinking I need a thicker/better screwdriver, anyone have one that they would be willing to volunteer?
    Thanks.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Re: Another stuck oil filter...
    how the hell did you strip the 17mm nut welded on the top? you're pretty much stuck doing the hammer & screwdriver trick
    Dedham
    It was already slightly stripped.... Meaning I think it was tightened to the point of stripping that nut.
    I have done the screwdriver trick, and snapped one in the process. Anyone have like a titanium screwdriver?
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    sounds like you're tightening these filters way too much. i guess you could try using a standard wrench on the nut & see if it works
    Push directly on the end and turn at the same time.
    Dedham
    First time I'm changing the oil on this one- I usually do it hand tight and clamp+safety wire or just safety wire for the K&N types. I'll keep workin at it.
    Bergs- I tried that, I read your post in the older oil filter thread... I'll try it again, don't want to knock the bike off the stands.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Trust me. Push directly on the end and turn at the same time.
    Trust me. Push directly on the end and turn at the same time, while using vicegrips
    Fixed.
    Dedham
    Assuming the friction of the rubber seal between the filter and the housing is creating the resistance, wouldn't adding more pressure to the seal increase the friction even more?
    I have tried it- but just trying to figure out how it works.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Quote Originally Posted by viva_brasil View Post
    I'm pretty sure he meant pushing on the wrench so the socket could get more grip on the stripped bolt.
    If you can put the rear tire up against a wall or some other solid object, that will allow you to really crank on it.
    I mean push directly on the end of the filter. Yes, the friction on the o-ring will increase but the real issue is the amount of pressure against the threads as a result of the o-ring trying to expand. If you push in on the filter you will be releasing some of the pressure on the threads. The trick is turning the filter at the same time.
    Dedham
    My "turning" is being limited by the screwdriver which broke. Because of the limited space and stuff around the filter, the only direction I can really crank is downwards- so it isn't pulling the bike back.
    The nut is completely stripped. I hammered a smaller socket on it but couldn't get it all the way over the nut- and then cranked on that until it stripped again.
    Maybe my sockets aren't ideal- they're the ones with many little "teeth".
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Dedham
    Does anyone have a good oil filter clamp tool that works with smaller oil filters?
    I got the smallest one I could find at advance auto parts, and it has to tighten all the way to get a grip on the filter. I only have so much room to add rubber stuff as a damper...
    If I could keep the handle on the filter clamp straighter, it would do more twisting and less denting/pushing...
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    I've never liked the screw driver trick..not only is it messy, but half the time it doesn't work.
    A trick that has always worked for me with tight filters, I loosen the filter first while the bike is cold, then snug it back up before I warm up the bike for the oil change. The hotter the engine, the more parts expand, the tighter the filter will get
    You're best bet at this point is to try and make a notch or goove (dremel tool) in the filter ring as close to the engine as possible. make it deep enough that a screw driver tip will catch it, then tap the screw driver with a hammer in the loosening direction
    Gotta find someone with oil filter pliers rather than the band-type wrench.
    THESE:
    Senior Member netra709's Avatar
    Oct 2007
    I went through this with the vfr this year. I ended up going to autozone and getting a oil filter wrench, that was basically a chain that wrapped around the filter, you just adjust the chain to the size of your filter. I had to take off a smog canister to get it, but it worked. Good luck.
    Dedham
    Yea my kickstand is the only thing I could move that is making it hard to move around more with the band-style clamp (which sucks anyway). I tried to remove my whole kickstand assembly, and ended up breaking an allen in the process.
    At this point I'm going to look for a better oil filter clamping tool. I don't think the pliers will do it because I'm going to need to create more leverage somehow- and I can't do that if I'm grabbing on the pliers...
    The bike has been cold since I started. I also let the oil flow out while it was cold- maybe should have warmed it up, I know there's different opinions on that.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Dedham
    Didn't understand this at first, but now I get it... will try in the morning since I don't have to buy anything to do it.
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    Derry NH
    I have one of these I can bring over along with some other tools and such I you want. I'm free tomorrow.
    Dedham
    Quote Originally Posted by Eric Baker View Post
    sounds good- sending u a pm...
    Current:
    00 Aprilia RSV-R
    Past:
    06 R6
    05 R6
    97 Honda F3
    #331 CBR929RE's Avatar
    Bridgewater, MA
    those R6s have the oil filter in the worst friggen spot.
    you need a better screwdriver. Go get a big craftsman. should be better than what you have and if you break it you can just get a new one for free.
    Lifer 01xj's Avatar
    CT
    If its still stuck, try a strap wrench. Thats how I take mine off. For 10$ they're a great investment.
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    +1 on the strap wrench. i have a rubber type craftsman one that works great.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
    Nov 2007
    That guy should work, i've used one of those with great success before on a too-tight filter...
    Zip-Tie Alley Racing
    LRRS/CCS #103
  1. K&N X-Treme Motocross air filter vs. Foam filter?
    By Ductard in forum General Bike Related
    Last Post: 07-14-15, 01:05 PM
  2. Really stuck KLR
    By markbvt in forum General Bike Related
    Last Post: 08-13-10, 11:25 PM
  3. stuck!
    By SVRACER01 in forum Dirty Bastards
    Last Post: 06-09-08, 06:15 AM
