Would anyone happen to have a double banjo bolt for a gsxr? I have been trying to get in contact with Galfer but with no success. I just need the banjo bolt along with washers. 06 gsxr 600
Shannon
I might. What's the banjo size? It's smaller than the sv right?
That's a great question that I do not know the answer to. Paging Jim and Pigman.............................................................
Shannon
i have a double banjo from a spiegler line ( i assume it'll be the same) but it's for a brembo mc. i have some single banjos if u need them for stock mc
Wirelessly posted
Brembo MC takes a finer thread.
I'd ditch everything Galfer and get a new set of lines. Galfer sucks. Unless you want your lines failing....then you should keep them on there.
I had a line fail on my r6 this year where the line meets the fitting at the crimp. They were new at the beginning of the year. When I posted it on fb many others posted the same problem. That's enough for me to stay away. Jim would use them because he is sponsored by them.
Giggity
Shannon
