Results 1 to 8 of 8
how hard is it to put a new exhaust on?
    Apr 2004
    Cambridge
    I just received my new yoshimura carbon fiber exhaust and I was wondering if anyone knew how hard it would be to take the stock one off and put this on? It is the full system including headers, and I have a factory jet kit that is going to be put on in a couple of days, but for now I just want to try and put it on on my own. Thanks
    Arguing on the internet is like winning a gold medal in the special olympics......whether you win or lose you are still retarded!
    I like them naked craig's Avatar
    May 2003
    Natick, MA
    It should be wicked easy like most "bolt-on" mods. Unbolt old one, bolt on new one. Mine took about 30 minutes and that's only because I had to realize the centerstand had to be removed for it to go on the bike
    Did it come with instructions/diagrams? do you have a service manual? that should give you an idea of how to take the stock one off.
    May 2003
    Lakes Region, NH
    either way shoul dbe pretty easy. Slip ons are a 20-30 minute job on most bikes and even full systems aren't that hard. My slip-on took my 20 and i helped a buddy of mine with his full vance and hines and the hardest part was realizing that the center stand had to come off.....
    Bras cause cancer.
    May 2003
    Natick, MA
    hahah we had the same problem nikon!
    May 2003
    Lakes Region, NH
    must be a south shore thing.....
    Bras cause cancer.
    Lifer Karaya One's Avatar
    Springfield, Mass
    Try installing a new exhaust on a 1993 GSXR-750 and see how "easy" it is.
    Remove the bodywork, drain the coolant, drop the radiator, pull the old exhaust, install a new oil filter because the new system fits so tight you can't get the filter off with it in place.
    Now, install new exhaust - make sure to install NEW exhaust port gaskets - and put everything back on.
    On some bikes this is easy, but that Gixxer comes to mind as the worst ever.
    Check out my eBay store!
    Dave - Motorace - Michelin
    May 2003
    Lakes Region, NH
    sounds like you got is all firgured out now...should be a snap next time
    Bras cause cancer.
    Springfield, Mass
    The only thing worse than that 1993 GSXR-750 was putting a head gasket in a 1994 GSXR-1100 with the engine still in the bike.
    No room to work, and you still have to drain the coolant since the thermostat is mounted on top of the valve cover.
    Those early wet GXSR's suck ass.
  1. For Sale - Parts & Tools | Lightly Used Rinehart Exhaust & Stock Exhaust 2020 Street Glide
    Last Post: 01-03-21, 03:09 PM
  2. Replies: 9
    Last Post: 08-02-08, 01:19 PM
